The tearing is only related to the frame rate and not related to the refresh rate?
Posted: 29 Nov 2024, 01:08
I am making a video about the advantages of a high refresh rate monitor, and I got a lot of inspiration from BlurBusters.
In my view, a higher refresh rate results in lower latency because the scan time for each frame is shorter; and less tearing because at the same frame rate, fewer frames appear in a single scan.
But after testing with the G-SYNC Pendulum Demo, I found that the tearing performance at 60Hz and 540Hz refresh rates was completely consistent at 60fps and 500FPS, which is very puzzling.
