The issue of Pursuit Camera With Motion Tests
lann
Post by lann » 13 Dec 2024, 00:25
Using a shutter speed of one-quarter of the refresh rate allows for accurate motion blur capture, but slower shutter speeds produce effects closer to real-world perception. When comparing motion blur on 60Hz, 120Hz, and 360Hz displays, should a uniform 1/15-second shutter speed be used, or should the shutter speed be adjusted differently for each case?
If perfect tracking is achievable, should all refresh rate displays use the slowest possible shutter speed?
lann
Re: The issue of Pursuit Camera With Motion Tests
Post by lann » 15 Dec 2024, 04:53
After I set up the test slider, all screens are tested with a shutter speed of 1/15s, right? This should be the fairest?
Post by Chief Blur Buster » 17 Dec 2024, 03:14
Hello,
Use a shutter speed of 4 refresh cycles. For 240Hz, that means 1/60sec. It's dictated by the design of the sync track. As long as you stack multiple refresh cycles, anything from 3 to 7 refresh cycles should look EXACTLY the same.
A properly done 1/30sec vs 1/60sec vs 1/45sec pursuit exposure at 240Hz should look exactly the same; but they look different because of photographer pursuit difficulty. Faster exposure is subject to less handshake/railvibrate/pursuit-mismatch error margins. So you get easier WSIWYG at faster exposure.
We have a pursuit camera forum, so I am moving the thread to the correct forum:
viewforum.php?f=23
- You don't have to use 4xHz always. For low Hz, you can use 3xHz, as long as you follow the guidelines (see diagrams posted in forum)
- We will be improving the sync track to allow tickcount adjustment (3xHz, 4xHz, 5xHz ... 8xHZ).
Currently we use a 4-tickout pursuit sync track, which makes it easiest at 4xHz, but 60Hz is very difficult at 1/15sec, so 3xHz is a compromise (1/20sec) to make it easier. Shorter exposures produces more reliable pursuit camera exposures that are easier to get closer to WYSIWYG.
Use these guidelines:
A 4-tick sync track is usable from 3 exposed refresh cycles (minimum) through 7 exosed refresh cycles (maximum), as long as you've become very good at interpreting the error margins in the sync track. A full 2x tickmark (8 refresh cycles) exposures can be confused by slowly-skewing bright tickmarks, giving you too many redherring effects.
TestUFO 3.0 will have an adjustable sync track and automatic helpers ("Exposure: 1/[##]sec") based on current tickmark count and automatically detected refresh rate.
Post by Chief Blur Buster » 02 Nov 2025, 16:06
lann wrote: ↑
15 Dec 2024, 04:53
TestUFO 3.0 now supports configurable tick marks of 3, 4, 6 or 8. 3 is tickmarks means you can use 1/20sec shutter for 60Hz, while 8 tickmarks means you can keep a slower 1/60sec for 480Hz (480/60 = 8).
It's based on the human vision eye averaging principle. You want a shutter speed slow enough to capture multiple refresh cycles, to mimic human vision averaging behaviors for temporally capturing multiple refresh cycles in one blur.
In essence "Make my handwave photo of the TestUFO Ghosting, as clear and sharp as possible, despite waving my camera at a slow shutter speed" -- and when done correctly, it's the exact same motion blur in the photograph/video, as your human vision saw.
Slower shutter speed is harder to do accurately manually so you want a slightly faster shutter speed to make your job easier -- but not too fast (you don't want to capture too few refresh cycles).
Too fast exposure = doesn't simulate human vision averaging
Too slow exposure = hard to track accurately manually
So you need to go goldilocks between 1/20sec and 1/100sec approx, with a sweet spot of 1/30-1/60sec. Basically not too far from your flicker fusion threshold (where your human eye averaging kicks in).
lann
Post by lann » 09 Jan 2026, 11:44
02 Nov 2025, 16:06
lann wrote: ↑
15 Dec 2024, 04:53
This is really good news, thank you for the help from Chief!
Post by Chief Blur Buster » 20 Jan 2026, 16:56
Error Margin Disclosure
Some researchers/scientists ask if results degrade with permitting large ranges of shutter speeds.
We find the TL;DR is no for most displays.
That's because for a continued pursuit at extreme high frame rates at high rerfresh rates -- motion blur generally looks the same. The more refresh cycles captured, the more it's blended/averaged. Beyond a certain point (but as long as pursuit is accurately tracked), capturing 3 to 8 refresh cycles look identical to each other in resulting photos if you pursuited perfectly.
The main error margins tended to be:
- Temporal dithering or FRC algorithms. This is more for full binary flicker (e.g. DLP) or extreme bright subfields (e.g. Plasma) than for LCDs, since LCDs are flickering adjacent 8-bit colors to generate 10-bit for example. This will generally be far below noise floor.
- Old displays + odd number captures. Some LCD displays has strong voltage inversion that flickers badly. For most accurate averaging of these, use even-number refresh cycle capture (e.g. 4). Modern LCDs generally don't have extreme strong flicker from LCD inversion so odd-numbered refresh cycles produce identical results to even-numbered refresh cycles.
- More camera shake (aberrations from perfect pursuts) over the time duration when capturing too many refresh cycles (but generally not an issue when refresh cycles are ultra-brief, like 480Hz).
I welcome further research/papers from others on this matter. Over the last 10 years, we've found that allowing a range of 3-10 exposures is fine for the pursuit camera sync track, as an analog to human vision averaging behaviors (vision integration).
The Blur Busters pursuit camera is still the low-cost gold standard even a decade later... (And you can still use it with motorized or automated cameras, if need be).
The sync track is the ground truth regardless of how it's pursuited by the >1000+ content creators in over 50 countries -- embedding camera tracking accuracy ground truth into the same images that are being analyzed.
