Asus tuf gaming vg259qm 60hz input lag settings?
MIrwali
Hi i bought asus vg259qm for ps5 main game ea fc (fifa)25 which is 60hz and i feel like input deley is high when i play cod warzone on 120hz there is good gameplay plus less input deley so which setting should i do for ps5 to get low input deley and good gameplay as i do only ea fc fut online Thanx
joseph_from_pilsen
Re: Asus tuf gaming vg259qm 60hz input lag settings?
Isnt it bad idea to buy monitor which has low input lag only at highest refresh settings?
- RealNC
It's not fixable. This monitor has abnormally high input lag at 60Hz. See:MIrwali wrote: ↑21 Dec 2024, 16:28Hi i bought asus vg259qm for ps5 main game ea fc (fifa)25 which is 60hz and i feel like input deley is high when i play cod warzone on 120hz there is good gameplay plus less input deley so which setting should i do for ps5 to get low input deley and good gameplay as i do only ea fc fut online Thanx
https://www.rtings.com/monitor/reviews/ ... #test_1435
120Hz: 4.8 ms
60Hz: 35.0 ms
Input lag is more than 7 times higher when going from 120 to 60. This is simply not a good monitor for PS5, or any gaming in general that needs 60Hz output.
MIrwali
it is working very well on ps5 cod warzone if ea fc become 120hz in future then it will work good and smoothRealNC wrote: ↑22 Dec 2024, 08:38It's not fixable. This monitor has abnormally high input lag at 60Hz. See:MIrwali wrote: ↑21 Dec 2024, 16:28Hi i bought asus vg259qm for ps5 main game ea fc (fifa)25 which is 60hz and i feel like input deley is high when i play cod warzone on 120hz there is good gameplay plus less input deley so which setting should i do for ps5 to get low input deley and good gameplay as i do only ea fc fut online Thanx
120Hz: 4.8 ms
60Hz: 35.0 ms
MIrwali
Which monitor should you recommend for ea fc 25 and also for future high fps games to get less input deley i will sell asus and get that model then
- RealNC
I don't know. But whatever you pick, check on rtings.com to make sure it doesn't have excessive lag at 60Hz. Not all PS5 games support 120Hz.
