dma remmaping disable (nvidia)
agendarsky
Post by agendarsky » 11 Jan 2025, 16:40
what about this guys, how does this feels to you?
navige to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\nvlddmkm\Parameters change DmaRemappingCompatible from 1 (3 was my case even its undocummented value) to 0 , restart and post if its doing nothing or something. :?
ahead
Re: dma remmaping disable (nvidia)
Post by ahead » 11 Jan 2025, 22:56
In Windows, the DMA remapping setting works as follows:
3 (Auto): Windows automatically manages DMA remapping.
0 (Disabled): Disables DMA remapping, which can slightly lower latency during address translation.
1 (Enabled): Forces DMA remapping to be enabled, prioritizing memory protection.
Disabling it (setting to 0) might reduce latency a bit, but for gaming, leaving it at 3 (Auto) is likely the best option. Still, you can experiment to see if changing it makes a noticeable difference.
JimCarry
Post by JimCarry » 12 Jan 2025, 06:37
does amd have it?
ahead
Post by ahead » 12 Jan 2025, 22:43
yes. Be cautious: Disabling remapping can have unintended effects, depending on the type of remapping in use.
JimCarry
Post by JimCarry » 13 Jan 2025, 02:07
ahead wrote:
12 Jan 2025, 22:43
so if i want to test what should i do?
and is this path only for nvidia users ?
ahead
Post by ahead » 13 Jan 2025, 07:21
Everything is simple; the result can be the opposite of what you expected.
JimCarry
Post by JimCarry » 14 Jan 2025, 04:12
ahead wrote:
13 Jan 2025, 07:21
ahead
Post by ahead » 14 Jan 2025, 20:47
DmaRemappingCompatible to 0 -> 1 -> 2.
JimCarry
Post by JimCarry » 15 Jan 2025, 04:25
ahead wrote:
14 Jan 2025, 20:47
i ask you about the reg path i dont even have it ?
ahead
Post by ahead » 15 Jan 2025, 23:38
Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\nvlddmkm\Parameters
