CRU HDMI 2.1 questions
- prod1G
What happens if i delete extensions override, disable SCDC present and disable DSC 1.2a in HDMI 2.1 extension?
ASUS VG259QM
SAMSUNG G60SD
MSIfanboy
Re: CRU HDMI 2.1 questions
not sure, if you want to risk it, make sure to export copy of the bin file CRU, and make sure you have another monitor, to get into CRU and reset it, to delete or fix/return the changes
and things could go wrong, so you might ruin the port or ruin your monitor
- prod1G
Already did it. Screen still working. Im just curious if these settings could yield some latency decrease.
With DSC 1.2a off it kinda feels snappier?. Could be placebo,tho.
ASUS VG259QM
SAMSUNG G60SD
- kyube
Your OSD should have information whether you're using DSC or not.
A rudimentary test, if you have a Nvidia GPU, is to check whether the time interval for alt-tabbing is shorter now.
I'm interested in your findings, keep us updated.
