Most 1440p monitors are slow...
Posted: 26 Jan 2025, 14:46
Hello guys, right now I am looking for a 1440p monitor specifically for games like warzone and battlefield, I have tried several older monitor options and they all have slow response times and input lag compared to my vg259qm.
These are my options, so I would appreciate any advice on them>
1)XG27WCMS VA panel, 280hz... I know the first thing people will say is that it's terrible for fps but this particular one is an interesting monitor and seems to be the same panel or very similar to the samsung g6 VA 240hz but without the tizen crap and 100% focused on gaming.
One reviewer Hello guys, right now I am looking for a 1440p monitor specifically for games like warzone and battlefield, I have tried several older monitor options and they all have slow response times and input lag compared to my vg259qm.
An asian youtuber (GTID) made a review of the 180hz version, very low input lag and ghosting, VERY high contrast and good response times, im tired of my ips looking like white paper with the sub 1000 contrast ratios.
2) XG27ACMG IPS 270hz... this monitor seems to be the same panel as the XG27ACS but in 270hz, so you can expect very good factory calibration, good colors and acceptable response times, virtually no reviews for this monitor so it would be a blind purchase.
3) VG27AQML1A IPS 260hz... for me it would be an instant buy if they were the same specs of the vg279qm but in 1440p, the problem is that apparently they have almost nothing in common, this may be the fastest of all???
4) XG27AQMR IPS 300hz... the most expensive of all and the one I like the least, the reviews of this monitor place it with mediocre response times, which do not go at all with its high frame rate.
ANY advice will be greatly appreciatedof th of the 180hz version, very low input lag and ghosting, high contrast and VERY good response times>
