netsh int tcp set global autotuninglevel=disable
hirecuery
Post by hirecuery » 27 Jan 2025, 12:27
hello everyone. for a long time I did not dare to describe this problem, but still I am not able to solve it on my own.
I play valorant, I moved away from my parents and felt problems with registering bullets.
I started changing routers, providers, and my game always felt different.
nevertheless, I found a cmd command that helped me. this is netsh int tcp set global autotuninglevel=disabled. but when I use it, I feel like my opponents see me much earlier than I see them, and I often catch a enemy ferrari peek. when I set this value to normal, the enemy's spikes are not that fast, but I have a problem registering bullets.
also, the clip from a vandal with disabled goes crookedly when it is smoother with normal.
I've tried a lot, but it's the only thing that gives me any usefulness. help me.
sry for my english :(
Re: netsh int tcp set global autotuninglevel=disable
Post by Slender » 27 Jan 2025, 13:14
interesting.
im use disabled value a lot of time, it gives me more stable gameplay, but yeah im notice that picking. Lets go with wireshark and make test with normal / disabled and send me results.
Post by Slender » 27 Jan 2025, 13:16
also, that command affect on bufferbloat
JimCarry
Post by JimCarry » 27 Jan 2025, 13:20
try mine
Post by Slender » 27 Jan 2025, 13:27
yeah try ctcp
hirecuery
Post by hirecuery » 27 Jan 2025, 13:29
Slender wrote:
27 Jan 2025, 13:14
interesting.
Okay, I'll do it when I get home.
Post by Slender » 27 Jan 2025, 13:43
also try that:
netsh int tcp set global nonsackrttresiliency=disabled
netsh int tcp set global ecncapability=disabled
netsh int tcp set global timestamps=disabled
netsh int tcp set supplemental custom tcpackfrequency=1
+ you can try disable rss / taskoffload (cpu will interrupt network)
Misha1337
Post by Misha1337 » 27 Jan 2025, 14:54
Slender wrote:
27 Jan 2025, 13:14
interesting.
You can try those other values
hirecuery
Post by hirecuery » 27 Jan 2025, 19:47
Slender wrote:
27 Jan 2025, 13:27
yeah try ctcp
idk why its default, i installed ctcp above. driver problem?
Снимок экрана (1).png (383.18 KiB) Viewed 25066 times
ahead
Post by ahead » 28 Jan 2025, 01:51
This relates to the TCP protocol.
Valorant, CS2, Call of Duty, Battlefield, and other FPS games use the UDP protocol to exchange information between servers and clients. The use of UDP for communication in FPS games can easily be found on this forum, other forums, through Google, or even by asking ChatGPT. Based on this, I have a question: *** *** *******? This is a rhetorical question, so please refrain from answering.
[Moderation Bot: Removed slur. We aren't X or Facebook.]
