Games wont run smoothly
Posted: 03 Feb 2025, 11:55
by KatLa
Hello,
Can anyone help me with nvidia control settings for smooth gameplay?
3070 ti & 5600x 32gb ram 3600 , MSI G274QPX Monitor
For some reason the games don't feel smooth, the fps is high but the game isn't smooth and feels like there is latency between what I am doing to what happens in the game
Not sure what to do
Re: Games wont run smoothly
Posted: 03 Feb 2025, 14:29
by dermodemon
KatLa wrote: ↑
03 Feb 2025, 11:55
Hello,
Not sure what to do
Try this. Maybe it will help
viewtopic.php?f=10&t=14206&p=111500#p111500
Posted: 03 Feb 2025, 15:27
by KatLa
Any risk in doing that? I saw some people mentioned not to try some of the options on windows 11.
Posted: 03 Feb 2025, 18:49
by RealNC
KatLa wrote: ↑
03 Feb 2025, 15:27
No, they're safe. But make a note of what you changed or added to the registry so you can change it back or remove it later when you realize it won't help :P
Posted: 03 Feb 2025, 21:52
by KatLa
RealNC wrote: ↑
03 Feb 2025, 18:49
KatLa wrote: ↑
03 Feb 2025, 15:27
Any other suggestions in your mind? something to do with the bios or anything? any game wont run smooth, just doesn't feel right
Posted: 05 Feb 2025, 01:54
by SeekNDstroy
You can check calypto's latency guide or boringboredom's github guide.
Do anything at your own risk & do it carefully with some own research. Search the keyword in google/ see what's the opinion that has discussed in trusted forums / reddit / discord servers.
Applying various tweaks without knowing the effect can decrease your performance.
