Aint XMP makes it worse for you ?
amorou
Every place I tried , higher ram speeds makes it "a lot" worse
Hyote
Re: Aint XMP makes it worse for you ?
No, as with everything else the honeymoon phase goes away. Tighter timings with lower frequency used to give me faster feeling inputs but in reality I was doing worse in games. Underclocking can be worth it but only as long as the stability gain is worth the performance loss.
amorou
Well at cpu bounds games %1 lows will be much better with high ram freq.Hyote wrote: β17 Feb 2025, 17:45No, as with everything else the honeymoon phase goes away. Tighter timings with lower frequency used to give me faster feeling inputs but in reality I was doing worse in games. Underclocking can be worth it but only as long as the stability gain is worth the performance loss.
"Doing better at games" will mean very different things depending on elo
My experience is consistently over the 5 years higher ram speed always make issue worse
- n1zoo
xmp = more frames, less time to react to player peeks. It doesn't matter what model of RAMs. At least that's the feeling when you have inputlag.
donktuman
not in my case.
Both xmp and no xmp feels same. so id rather have xmp on
- Slender
yes, that's true. For some reason, the memory with default settings feels better.
What does xmp do?
xmp changes the memory frequency, timings and voltage.
In order to better understand the reason, let's take the memory 3600cl14-14-14-34 1.45v dr real 1n (SA 1.35v), and turn off xmp.
Without xmp, the memory takes the values ββ2133 cl15 1.2v (1.2v SA).
I go into the game and see a noticeable drop in fps, but expectedly better input. What could be the reason? Since the timings in my case do not matter (cl15 def vs cl14 xmp), the voltage and memory frequency remain. In order to exclude the frequency from the equation, i will take the default value of 2133 and change the timings to approximately match 3600cl14. For our memory, this will be 8-8-8-20 or 9-9-9-21 (both options work without errors). The voltage in this case remains 1.45v (1.35 SA).
Launch the game - the fps has increased, but the input has become the same as before.
The voltage remains.
I turned on the xmp profile and lowered the SA voltage to the default 1.20v. The memory worked without errors, but this did not improve input.
I lower the memory settings to the default 2133 cl15 1.2v and enter the game (to exclude placebo). And expectedly low fps and good input.
I increase the voltage of the default memory to 1.45 (sa 1.35) and observe the same problems as with xmp.
What does xmp do?
amorou
I suspect high impedance grounding , as higher speeds will produce more noise in circut.
Gotta research how to measure groundings impedance and test it
TN_fun
So it turns out that voltage and timings make the input better. or just voltage?Slender wrote: β18 Feb 2025, 21:27yes, that's true. For some reason, the memory with default settings feels better.
What does xmp do?
How about undervolting the GPU? I notice that undervolting makes my games smoother. I can't say about reducing input lag, it seems to me that it remains the same. But the fact that undervolting makes my games smoother is 100% I checked several games. (these are only 1660s)
Reducing the voltage on the CPU seems to also improve the input and make games smoother. I specifically checked this in old games (quake live), so that reducing the frequency and voltage of the CPU does not affect the fps
- Slender
yes, in my case lowered voltage of gpu / cpu / ram reduce this issue. Frequency / Timmings is not affect.TN_fun wrote: β19 Feb 2025, 15:54So it turns out that voltage and timings make the input better. or just voltage?Slender wrote: β18 Feb 2025, 21:27yes, that's true. For some reason, the memory with default settings feels better.
What does xmp do?
