Would rlly appreciate some help with getting the right flip model on my game
awuhdlaui
Post by awuhdlaui » 25 Feb 2025, 21:09
Hey guys, would just like some help with making my game run with Hardware composed : independent flip instead of hardware : independent flip as I have read that it's better. Always searching for the best mouse feel for games like cs2 and valorant and hope this will help a bit more with that.
Screenshot 2025-02-26 130740.png (7.16 KiB) Viewed 7993 times
Panychkaaa
Re: Would rlly appreciate some help with getting the right flip model on my game
Post by Panychkaaa » 26 Feb 2025, 10:25
HKEY_CURRENT_USER\System\GameConfigStore\Children\ -> Search (VALORANT-Win64-Shipping.exe) -> Flags -> 211
1000WATT
Post by 1000WATT » 26 Feb 2025, 11:30
awuhdlaui wrote:
Instead of
You want?
awuhdlaui
Post by awuhdlaui » 01 Mar 2025, 20:37
Panychkaaa wrote: ↑
26 Feb 2025, 10:25
Hey, I tried this on cs2 and it made my game run in Hardware : legacy flip. I remember watching a video about the reg edit, pretty sure it just disables fullscreen optmizations.
In the attachment it says to achieve hardware composed : independent flip that i need directflip optimizations. ahh just realised that it says i need multi plane overlay enabled but I thought i did. pretty sure i do have it enabled unless i somehow disabled it in a tweak? Would you happen to know a way to force MPO?
awuhdlaui
Post by awuhdlaui » 01 Mar 2025, 20:39
yeah. Just looked around and seen that its apparently better, you should be able to see the image of the different flip models in my reply to the other guy above. Its saying that i dont have mpo enabled but it doesnt make sense, because im pretty sure I do. unless its outdated.
Post by RealNC » 01 Mar 2025, 21:32
"Hardware composed: independent flip" is what I get with MPOs enabled. "Hardware: independent flip" is with MPOs disabled (due to HDR or DSR.)
That's on Windows 10 though.
awuhdlaui
Post by awuhdlaui » 01 Mar 2025, 22:38
RealNC wrote: ↑
01 Mar 2025, 21:32
do you think that using scaling, like stretching 4:3 in cs or valorant would effect it? Is there a way to tell if mpo's are enabled or not?
Post by RealNC » 01 Mar 2025, 23:08
awuhdlaui wrote: ↑
01 Mar 2025, 22:38
I use SKIF (SpecialK's GUI frontend) to check it:
kyube
Post by kyube » 02 Mar 2025, 09:29
RealNC wrote: ↑
01 Mar 2025, 23:08
awuhdlaui wrote: ↑
01 Mar 2025, 22:38
Reminder for anyone attempting to use SK:
Special K does not work in games which use a kernel-level anti-cheat and may trigger a ban, as it injects into the process itself.
The alternative is, use PresentMon to find out the flip mode of a game.
JimCarry
Post by JimCarry » 02 Mar 2025, 11:19
Panychkaaa wrote: ↑
26 Feb 2025, 10:25
i dont have these keys i delete them long time ago,any other way? i have mpo disabled and in gameconfigstore everything is on 0.
