Very Possible Solution to Desync and Heavy Mouse
osterhase
Alright Guys, This fix is actually very possible to solve this common Issue stated in this Title. In my Case its a GIGABYTE b760m DDR4 DHS 3 moterboard. Go to BIOS (a Bios reset will NOT fix this in my case), then go to Settings and then to PC HEALTH. If you see that next to: Case open, it says YES even though your case is closed and pc is closed, then press reset, which will say after it reboots, that case is closed. This INSTANTLY fixed all my Problems which I had with desync. I think the motherboard throttles and fluctuates when it thinks the case of the pc is open, so that would make lots of sense. Please test it out, even though u might have another motherboard than me. The difference is absolutely crazy.
- RealNC
Re: Very Possible Solution to Desync and Heavy Mouse
Banned. Every thread you created is a troll.osterhase wrote: ↑01 Mar 2025, 12:20Alright Guys, This fix is actually very possible to solve this common Issue stated in this Title. In my Case its a GIGABYTE b760m DDR4 DHS 3 moterboard. Go to BIOS (a Bios reset will NOT fix this in my case), then go to Settings and then to PC HEALTH. If you see that next to: Case open, it says YES even though your case is closed and pc is closed, then press reset, which will say after it reboots, that case is closed. This INSTANTLY fixed all my Problems which I had with desync. I think the motherboard throttles and fluctuates when it thinks the case of the pc is open, so that would make lots of sense. Please test it out, even though u might have another motherboard than me. The difference is absolutely crazy.
