DX9 games and Flip presentation model
witega
Post by witega » 03 Mar 2025, 11:37
Does anyone know if the following is accurate, based on my testing it seems there are only two presentation models for DX9 games on Windows 11:
Hardware: Legacy Flip
Composed: Copy with GPU GDI
If using Fullscreen Exclusive with disabling FSO in the game's properties, the presentation model will be Hardware: Legacy Flip.
However if using a borderless or windowed setting, enabling FSO and "Optimizations for windowed games" enabled (Settings->System->Display->Graphics->Default graphics settings) this will only give me a Composed: Copy with GPU GDI.
Is there no way to force DX9 games to use the Flip presentation model? I have an issue with an older DX9 game that whenever I use FSE it forces my display panel to use 60hz, which is undesirable as the display lag of my monitor is higher at this refresh rate. But doing borderless/windowed results in the worst presentation model with Composed: Copy.
Most of my other DX9 games can run FSE without changing my display's refresh rate so not sure the cause here.
Appreciate any help here!
Re: DX9 games and Flip presentation model
Post by RealNC » 03 Mar 2025, 15:13
witega wrote: ↑
03 Mar 2025, 11:37
Only if the game uses DX9ex. Which is rare.
But you can use dxvk or dgVoodoo2 to run DX9 games on top of Vulkan or DX11.
witega
Post by witega » 07 Mar 2025, 21:54
Thank you very much RealNC for responding, much appreciated. Turns out I was able to get HW Independent Flip on a DX9 game by modifying the game's config file to go beyond 60hz.
I may have to take a look at dgvoodoo2 though for DX8 games, so appreciate the suggestion there. :)
Post by RealNC » 08 Mar 2025, 02:42
witega wrote: ↑
07 Mar 2025, 21:54
SpecialK has some experimental options to force DX9ex in DX9 games as well. However, it's very hit and miss whether it will work or not.
