Process Lasso Dynamic Thread Priority Boosts
PatheticBot
Post by PatheticBot » 13 Mar 2025, 11:38
Whenever I try to set this it seems to set itself back on. I disable this as it gives my game noticeable desync but then out of the blue while playing ill lag for a second and when I check its somehow turned itself on.
Is valorant making this change or do I need to find a way to lock this setting down?
Routine4493
Re: Process Lasso Dynamic Thread Priority Boosts
Post by Routine4493 » 22 May 2025, 05:57
I really dont know if it makes a difference activating or dis-activating Dynamic Thread Priority Boosts for you game......
But I know why it is disabling........ The answer is: Anti-Cheat. If I remember correctly this game has kinda an launcher before it process is started. So you need to set all your process lasso configs to the the launcher and home it is carried over to the game process.
I know it have to be like that for Battlefield 2042. I need to set my configs to the EA.exe and then it is carried to the game exactable when i click play inside the game library.
Try it and say to me if it worked.
Important note, you have to kill all processes related to the launcher for it to work, or you can restart the PC all together before executing it, or may be some process hidden that you did not saw
