Help With Optimal Forza Motorsport Stable G-Sync / V-Sync Settings for Multiplayer
Posted: 30 Mar 2025, 16:45
Hi all,
First I apologize if this isn't the right forum subcategory for this type of discussion. This game is incredibly annoying to optimize for due to the game capping multiplayer to 60 fps but it is clear that it is not a stable cap as I still see fluctuations slightly above 60 fps. I am going crazy having tried so many settings combinations and tips from many different sources. I am still stuttering during cornering especially on almost all tracks affecting my race pace. This game is also weird that it runs best with v sync enabled in game and forced on in control panel. I just did a fresh DDU and on latest drivers due to another issue i was having.
System
GPU: 4080 Super (Stock Bios - Afterburner not installed)
CPU: 7800X3D (PBO UV -20, Rebar Enabled)
Monitor: AW2725DF - 360Hz 1440p (HDR off)
NVCP Game Specific Settings Changed v Default
Running full 360hz - i have heard people have had success turning high refresh rate monitors down to 60 hz but really want to avoid that
LLM - Ultra - have tried off on and ultra and ultra has felt best but
Max Frame Rate - 120 FPS brought this down for stability even though it is above in game frame cap the game likes to cap based on monitor refresh rate and wanted a lower base line than 360 fps
G Sync Enabled - Full Screen Mode
V-Sync On
Other
Nvidia Sharpen+ Freestyle Filter ON
In Game Settings
Dynamic Render Quality - High (not ultra due to running at 1440p which high settings internal resolution is apparently)
Dynamic Optimization - Custom
Fullscreen - On
Resolution 2560 x 1440 (DSR not available for this monitor because of DSC)
Resolution Scale - 150% (game is incredibly blurry at 1440p)
TAA - On (im not opposed to DLAA but then res scale is not adjustable)
My biggest question is....
Performance Target - 60 FPS (V-Sync); i have tried everything but dont know which to use here coupled with my NVCP setttings e.g. Unlocked, Unlocked (V-Sync), 60 FPS
Many thanks in advance!
System
V-Sync On
Other
In Game Settings
Fullscreen - On
