heres mine just sat on desktop.
i know what you mean tho by it not feeling as "responsive"
i use a lot of latency tweaks. If you want to try them out, make a system restore point and try each of these, in order, 1 by 1 and see how it feels for you
download gointeruptpolicy
https://github.com/spddl/GoInterruptPolicy. for your gpu and the pcie express root port its connected to, enable msi mode if its not already enabled, select device policy, irqpolicyspecifiedprocessors then assign it to 1 core. choose an even threads not an smt thread. you can check cpus tab on latencymon and find which core has the less isr/dpc processing going on then choose this. -this helps a lot with 1% lows and msi interupts causing small micro stutters.
choose a thread for each usb controller-disable any that you arent using. Make sure your usb controller that moues is connected to is on its own thread. you can get away with having the other controllers on the same thread as something else if there isnt any high polling devices connected to it. try keep mouse controller as close to core 0 as possible due to intercore latency. A lot of people recommend avoiding settings affinity to core 0 for anything as thats where msot of interupts and windows processing happens. but i have the best results as ive assigned a lot of things off to dif cores already. it avoids the intercore latency there.
Next up are some reg tweaks PLEASE make sure to make a restore point (not as important as setting msi mode but its still advised as changing msi setting for storage can mess up boot)
apply them in order, 1 group at a time and test(every ENTER space will devide the groups
12
12
131
414
122
like this)
but first, download and run this bat to disable power saving for devices(you can right click and edit in notepad to view contents if youre wary of running downloaded bats)
https://drive.google.com/file/d/1JZ5hCr ... sp=sharing
now,
reg add "HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\Kernel" /v InterruptSteeringDisabled /t REG_DWORD /d 1 /f
reg add "HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\dwm.exe\PerfOptions" /v "IoPriority" /t REG_DWORD /d "3" /f
reg add "HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\csrss.exe\PerfOptions" /v CpuPriorityClass /t REG_DWORD /d 4 /f
reg add "HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\csrss.exe\PerfOptions" /v IoPriority /t REG_DWORD /d 4 /f
reg add "HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\Kernel" /v ThreadDpcEnable /t REG_DWORD /d 0 /f
reg add "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\kernel" /v DpcWatchdogProfileOffset /t REG_DWORD /d 0 /f
reg add "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\kernel" /v DpcTimeout /t REG_DWORD /d 0 /f
reg add "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\kernel" /v IdealDpcRate /t REG_DWORD /d 1 /f
reg add "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\kernel" /v MaximumDpcQueueDepth /t REG_DWORD /d 1 /f
reg add "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\kernel" /v MinimumDpcRate /t REG_DWORD /d 1 /f
reg add "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\kernel" /v DpcWatchdogPeriod /t REG_DWORD /d 0 /f
Reg.exe add "HKLM\SYSTEM\CurrentControlSet\Control\PriorityControl" /v "ForegroundBoost" /t REG_DWORD /d "1" /f
Reg.exe add "HKLM\SYSTEM\CurrentControlSet\Control\PriorityControl" /v "ThreadBoostType" /t REG_DWORD /d "2" /f
Reg.exe add "HKLM\SYSTEM\CurrentControlSet\Control\PriorityControl" /v "ThreadSchedulingModel" /t REG_DWORD /d "1" /f
Reg.exe add "HKLM\SYSTEM\CurrentControlSet\Control\PriorityControl" /v "AdjustDpcThreshold" /t REG_DWORD /d "800" /f
Reg.exe add "HKLM\SYSTEM\CurrentControlSet\Control\PriorityControl" /v "DeepIoCoalescingEnabled" /t REG_DWORD /d "1" /f
Reg.exe add "HKLM\SYSTEM\CurrentControlSet\Control\PriorityControl" /v "IdealDpcRate" /t REG_DWORD /d "800" /f
Reg.exe add "HKLM\SYSTEM\CurrentControlSet\Control\PriorityControl" /v "SchedulerAssistThreadFlagOverride" /t REG_DWORD /d "1" /f
reg add "HKLM\SOFTWARE\Microsoft\WINDOWS\DWM" /v UseHWDrawListEntriesOnWARP /t REG_DWORD /d 1 /f
reg add "HKLM\SOFTWARE\Microsoft\WINDOWS\DWM" /v ResampleModeOverride /t REG_DWORD /d 1 /f
reg add "HKLM\SOFTWARE\Microsoft\WINDOWS\DWM" /v RenderThreadWatchdogTimeoutMilliseconds /t REG_DWORD /d 0 /f
reg add "HKLM\SOFTWARE\Microsoft\WINDOWS\DWM" /v ParallelModePolicy /t REG_DWORD /d 1 /f
reg add "HKLM\SOFTWARE\Microsoft\WINDOWS\DWM" /v EnableResizeOptimization /t REG_DWORD /d 1 /f
reg add "HKLM\SOFTWARE\Microsoft\WINDOWS\DWM" /v EnableMegaRects /t REG_DWORD /d 1 /f
reg add "HKLM\SOFTWARE\Microsoft\WINDOWS\DWM" /v EnableFrontBufferRenderChecks /t REG_DWORD /d 0 /f
reg add "HKLM\SOFTWARE\Microsoft\WINDOWS\DWM" /v EnableEffectCaching /t REG_DWORD /d 1 /f
reg add "HKLM\SOFTWARE\Microsoft\WINDOWS\DWM" /v EnablePrimitiveReordering /t REG_DWORD /d 0 /f
reg add "HKLM\SOFTWARE\Microsoft\WINDOWS\DWM" /v OverlayQualifyCount /t REG_DWORD /d 0 /f
reg add "HKLM\SOFTWARE\Microsoft\WINDOWS\DWM" /v OverlayDisqualifyCount /t REG_DWORD /d 0 /f
reg add "HKLM\SOFTWARE\Microsoft\WINDOWS\DWM" /v ResizeTimeoutModern /t REG_DWORD /d 0 /f
reg add "HKLM\SOFTWARE\Microsoft\WINDOWS\DWM" /v ResizeTimeoutGdi /t REG_DWORD /d 0 /f
reg add "HKLM\SOFTWARE\Microsoft\WINDOWS\DWM" /v HighColor /t REG_DWORD /d 1 /f
reg add "HKLM\SOFTWARE\Microsoft\WINDOWS\DWM" /v DisableDrawListCaching /t REG_DWORD /d 1 /f
reg add "HKLM\SOFTWARE\Microsoft\WINDOWS\DWM" /v AnimationsShiftKey /t REG_DWORD /d 0 /f
reg add "HKLM\SOFTWARE\Microsoft\WINDOWS\DWM" /v AnimationAttributionEnabled /t REG_DWORD /d 0 /f
reg add "HKLM\SOFTWARE\Microsoft\WINDOWS\DWM" /v EnableCommonSuperSets /t REG_DWORD /d 1 /f
if you see an improvement go to next, if worse skip and try next. if youre happy then stop there and dont apply more to avoid any instabilities anywhere. Also make sure you have set your global timer reslution -
https://www.youtube.com/watch?v=_Gi1PLg ... l=Hickensa
