Nvidia/AMD Scaling options effect on mouse input and input lag
Posted: 12 Apr 2025, 05:27
by Quajila
I always see people saying to use No Scaling for NVIDIA users, but they never get into how it affects mouse input (assuming it also affects it like on AMD). All I ever hear them say is "if you're using a native resolution use No Scaling".
When it comes to AMD, I never see anyone talking about the scaling options. In optimization videos they usually just skip the setting, leave it at default (aspect ratio), or change it to full screen. No explanation as to why, or about the effect on mouse input.
NVIDIA has No scaling, aspect ratio, and full screen.
AMD has Center, aspect ratio, And full screen.
From my understanding, Center and No Scaling are similar but not exactly the same.
I have an AMD RX 6600XT and when I use the Center scaling option, my mouse feels faster, almost like my sensitivity in games is faster. When i use Aspect Ratio, it feels a little slower (like some sort of smoothing maybe? idk), Feels like my sensitivity is also slower in games, and when I use full screen, It feels terrible. It feels distorted, like my mouse movements don't match whats happening on my screen, and it also makes my mouse and in game sensitivity feel way way slower.
This is also with the scaling overriding the scaling settings by games, but when I don't override the scaling set by games, it defaults back to Aspect Ratio which just ends up feeling the same as if I were to still be using Aspect Ratio and overriding the scaling set by games.
Another thing I notice is that they each feel different in terms of Input Lag, but then as im testing them, I don't know if I'm really feeling a difference or if it's just placebo.
I also notice that it looks like my FOV changes in games. Depending on what scaling method I'm using, my FOV will look taller or wider.
Re: Nvidia/AMD Scaling options effect on mouse input and input lag
Posted: 12 Apr 2025, 17:47
by JimCarry
Quajila wrote:
12 Apr 2025, 05:27
i have amd and i can confirm 100% that most of it is true,for example if you change to center do benchmark,then change to aspect ratio restart pc and do the same benchmark,you will see the results,i think on fullscreen its best for fps games,on no scaling looks better.
Posted: 02 May 2025, 03:17
by RamenRider
For AMD, GPU Scaling on is the way to go, for some reason display scaling is terrible for me. And the 3 scaling options, I need to retest them.
Posted: 07 May 2025, 11:25
by amorou
Yes on every system I tried no scaling produce lower mouse delay
however
if you noticed gpu scaling make non-constant fps appear smoother , like if it improve %1 lows. But it adds mouse lag also.
Just like that with fullscreen mouse gets hit but games appear smoother.
So its like levels of mouse/visuals tradeoff for me
Posted: 07 May 2025, 15:12
by JimCarry
for amd there are 3 option every option is a new feel,so for cs2 4by3 res can someone do benchmarks,or explain wich of the 3 options is best ?
Posted: 14 May 2025, 08:14
by BrandonBryant
I’ve noticed similar effects with AMD scaling too. Center feels snappier, but Fullscreen messes with input. It definitely impacts sensitivity and FOV. Maybe it’s a mix of input lag and visual distortion?
