Some problem with pc
SKILLEN
Post by SKILLEN » 16 Apr 2025, 16:33
Yes i have mouse lag problem since late 2018 but...
5700x3d
2x16 3600mhz
512gb 970evo
Seasonic 850W platinum
I stopped playing cs 2023 august and bought current PC 2024 march or april. Since then im playing even worse than usual its more difficult to win fights,cant peek ,cant react.I tried valorant and this new game fragpunk ,but i dont know if i notice something wrong,because i dont play these games.
In last 3 months i changed cpu,cooler,motherboard, no difference. Only the gpu left and i had old amd 550 2gb so i decided to try it. Immediately i noticed how much easier is to kill and there is no more prefires,also in valorant and fragpunk it was much easier.I was better with 50-100fps than before with 200-400. So i decided my gtx 1080 was faulty or something. Today i bought cheap 1060 6gb to have at least decent fps before i buy something new. Now i have good fps again,but i cannot kill.
amd 550 is connected directly to the motherboard without cables .I had GT 1030 also directly to the motherboard with no such problems like i have with 1080 and 1060.
I have no idea what is happening.
amorou
Re: Some problem with pc
Post by amorou » 16 Apr 2025, 17:16
Well , yes.
Rx 580 , gtx 970 , much worse than 1050ti
Post by Slender » 16 Apr 2025, 17:38
PSU / Components consumption
SKILLEN
Post by SKILLEN » 16 Apr 2025, 17:47
amorou: in your case worse how? I have much higher fps with the stronger card
Slender: what does this mean? Faulty Psu?
joseph_from_pilsen
Post by joseph_from_pilsen » 17 Apr 2025, 05:48
Maybe you should get an AMD somewhat performant card, there are few people at reddit who reported issues with ngreedia cards but good gameplay with amd cards (and it were more than single digit number of strangers). Usually its not the card issue but the combination of HW which from some stupid reason unfavours ngreedia cards making them run worse feeling-wise in this case.
But i have to warn you that 1060 level of card is still too low, skip RX580 polaris and go with some 6700XT, 6800XT, 7700XT etc. The GPU even if seems not be fully utilized, there are moments when it microlags in cs2 at weaker GPU even if they report 70 percent load peek, in reality its 40 and 100 during milisecond.
Yeah and also last ngreedia drivers are... bruh.
I suppose you have got friends and you can lease a card for a test from them for a test.
If not, you can come to Czechia and i may try to help you, i live in a nice spa town now with many natural beauties, and there is an express train connection to Prague and enough room in house for guests and 2 computers with high frequency monitors :lol:
SKILLEN
Post by SKILLEN » 17 Apr 2025, 07:40
joseph_from_pilsen wrote: ↑
17 Apr 2025, 05:48
Thank you for the good offer ;D . I also thought about that nvidia vs amd,but when i saw cs2 streamers 99% were playing with nvidia and i tried 1030gt which is even weaker than amd 550 and it was okay i decided its not about nvidia or amd. I can't try newer card for now,because i have benq 2411 ,no hdmi and display port. Yes 1060 is old and low end ,but still on 800x600 i have p1 205 and 510avg . Now im scared even to buy new cards ,because it can be still bad and waste of money.
kyube
Post by kyube » 17 Apr 2025, 10:22
SKILLEN wrote: ↑
16 Apr 2025, 16:33
5700x3d
2x16 3600mhz
512gb 970evo
Could you detail your entire hardware configuration (Mobo, case, cooling, networking hardware) & software choices (GPU/USB/NIC drivers, OS optimisations, BIOS)?
Send a ZenTimings screenshot too, while you're at it.
JimCarry
Post by JimCarry » 17 Apr 2025, 15:04
17 Apr 2025, 05:48
ngreedia lel :D
InputLagger
Post by InputLagger » 17 Apr 2025, 18:38
JimCarry wrote: ↑
17 Apr 2025, 15:04
17 Apr 2025, 05:48
ngreedia lel :D
This is very accurate naming, to be honest..
SKILLEN
Post by SKILLEN » 17 Apr 2025, 22:13
kyube wrote: ↑
17 Apr 2025, 10:22
SKILLEN wrote: ↑
16 Apr 2025, 16:33
5700x3d
2x16 3600mhz
512gb 970evo
Today i bought 2nd hand rx 580 and psu and its okay now.
Still i will post zentimings to check everything is okay.
