solved Floaty Mouse- Reproducable fix-
Wrongmousemovement
Post by Wrongmousemovement » 22 Apr 2025, 16:39
Hey my floaty mouse sufferers,
I lurked on this forum for a long time, desperetaly trying to fix my floaty mouse (crosshair not there were you put it) Issue. Im excited to tell you that I 100% found a permanent fix for me which is reproducable. (fix is reproducable, and making the Issue happen again is reproducable) It took me a long time to find this fix and I am sure that some people will have the same problem as me, which messes up their aim a lot, leading to inconsistent gameplay and no chance to get good in any game.
The problem was, well, a mouse. But little did I know that 1 mouse could make your whole BIOS permanently buggy, which leads to a wrong initialisation to every next mouse put in, having the exact same Issues as the main faulty mouse. I obviously know this is rare as hell and weird and unbelievable but its a fact in my case. What I FINALLY did after 7 months, was reflashing my BIOS and then NEVER put my faulty mouse (G PRO SUPERLIGHT X WIRELESS) into my motherboard again. I instantly felt the huge difference in mouse feel. So I played a few days, my Issue never came back. But I had to make sure this was the Issue, so I put my faulty mouse back again, and BOOM, my whole system felt floaty again. No matter what other mouse I put in after, the problem didnt go away. I flashed my BIOS once again, and put my mouse which works fine in, no floaty aim at all.
Its crazy that one dongle or mouse can permanently "infect" or make the BIOS buggy. I could literally go to any PC right now and make it faulty forever until they reflash or flash the BIOS, or change Motherboard. Its absolutely crazy. For anybody who thinks im trolling as it sounds absurd (i know it does), I can literally put a video in the next days on this post showing this fix for proof. I would shoot bots in Valorant, or CSGO and you would instantly see how I would miss every shot in floaty system, but shoot very well on the flashed and no bad mouse put in after-system. I have no reason to troll.
My recommendation for people who suffer from floaty mouse a lot, being stuck in bad ranks for thousands of hours: You would have to firstly know which mouse is faulty. I knew it was the superlight because I got it with a new PC together, which firstly had this floaty Issue. When knowing which mouse is faulty in your case, put it away and never touch it again. Then flash BIOS to the same version, or if you have updates, update it. After that, put in a mouse where you are sure its not faulty. Youll see the difference instantly.
I hope I can help some people with this Issue. Probably not many people because I saw people crying about floaty mouse with high ranks, which is funny, and the Issue is probably very rare. I was one of the unlucky guys who had it sadly. Which makes sense, because the superlight is my only actually good mouse which I always took on new hardware thinking it wasnt a mouse Issue, as all mouses felt the same.
So yes, I found the Issue finally, Im so glad I never gave up, and as I said, the Issue is instantly reproducable. Come to my house and see it with your own eyes :D
This superlight will never see sunlight again
WARNING!: BIOS UPDATE AT YOUR OWN RISK - MAKE SURE NOT TO POWER OFF OR REMOVE FLASH DRIVE WHILE INSTALLING!
amorou
Re: solved Floaty Mouse- Reproducable fix-
Post by amorou » 23 Apr 2025, 09:48
Is this only about floaty mouse?
Did you have desktop-everyday tasks laggy/slow , high stable fps but lagging , erratic performance too?
Wrongmousemovement
Post by Wrongmousemovement » 23 Apr 2025, 11:12
amorou wrote: ↑
23 Apr 2025, 09:48
No i always had perfect performance, but the mouse was floaty. That was my (only) but huge Issue.
dervu
Post by dervu » 23 Apr 2025, 15:29
Send that mouse to someone who has experience in such things. Let's say optimumtech with hardware to measure differences and let's see.
supernoms
Post by supernoms » 23 Apr 2025, 17:03
So i tested this and hes right. It honestly doesnt solved getting prefired in cs2 as that seems like a completely separate issue. But I unplugged the suspected mouse, flashed my bios and im using my newer mouse(superlight 2) affected mouse was a logitech g703. My mouse feels exactly like that feeling i got when I bought an entire new pc all new parts etc. Im wondering now if someone will more knowledge could possibly find out whats going on here.
Ya new record in kovaaks so its definitely working
Bobo
Post by Bobo » 24 Apr 2025, 08:06
I can chip in with something regarding mice and bios.
I have a few mice i use, or used to use.
And many of them would have very low sensitivity in bios, the cursor would move very little. Some had this issue and some worked normal.
They all had the same dpi, so that wasn`t an issue, and they worked normal in windows, just had issues in the bios.
InputLagger
Post by InputLagger » 04 May 2025, 21:16
supernoms wrote: ↑
23 Apr 2025, 17:03
Try another keyboard also :idea: :twisted:
Post by Slender » 05 May 2025, 06:07
Wrongmousemovement wrote: ↑
22 Apr 2025, 16:39
mobo?
flash from bios / or usb from port ?
mbnz11
WHY DID THIS ACTUALLY WORK?
Post by mbnz11 » 20 Sep 2025, 02:30
I don’t know if you are reading this, you are a legend mate. This actually 100% fixed the problem for me. I literally went depressed for years trying everything possible in my power to fix this but never realized the mouse itself was a problem until I came across this and it made me realize each time I bought a new pc, ISP, went to a different location things were always fine until I plugged in my old razor mouse and that’s when the desync, mouse problems, Ferrari peeks, bad audio and video quality and terrible hitreg would start.
With that in mind, I went ahead and bought a new Logitech wireless 305 mouse, got bios update from my motherboards official support page on a flash and flashed my bios and instantly everything got fixed ON THE SPOT. GREAT AUDIO, VIDEO QUALITY AND THE GAME PERFECTLY IN SYNC I DONT GET INSTA ONE SHOTTED ANYMORE. You don’t realize how happy and refreshing it is to actually peek and play a game without the fear of knowing you are being handicapped by desync, lag and floaty mouse and not getting one tapped.
It’s been 3 months and the problem hasn’t returned ever since. BRO I’M ETERNALLY GRATEFUL, how did you even find this out? I think I’ll try to send my old mouse to razor so they can study how it messed up entire computers and how they function.
amorou
Re: WHY DID THIS ACTUALLY WORK?
Post by amorou » 26 Sep 2025, 16:52
mbnz11 wrote: ↑
20 Sep 2025, 02:30
Which model is razer one
