Symptoms are input lag, desync, faulty sensitivity, bad hitreg ,choppey& blurry picture.
Here are my findings. Please if you have any , don't hesitate to share! , this post will be updated if i discovered any new methods
1- using the correct power cord for your country voltage.
2- i found that using wired controller to the pc or Xbox cause huge input lag and bad hitreg and a massive disadvantage and unbearable gameplay so i used bluetooth and instantly noticed my aim became snappier and responsive.
1#update . i unplugged every single usb device that is plugged but the appliance (could be pc ,smart tv , tv box , satellite receiver etc) . is turned off ( can you imagine !!!) and that gave me more responsiveness and aim preciseness.
#2update, for some unknown reason turning off (dmz& upnp) on router settings improves hitreg, responsiveness, aiming preciseness
#3update, turning the 2 prongs power plug of the router upsidedown made huge improvement in aiming and responsiveness but still not perfect 🥲
These methods gave a good playable gaming experience but not perfect. Please share your solutions if you have same symptoms and fixed it!
I need to hear everybody's experience if they have one or more of these symptoms,Thank you all.
Sharing my findings and possible solutions regarding these symptoms
