240Hz - 60Hz Are there still losses when using dual monitors?
Posted: 08 May 2025, 06:16
I know that when using clone mode, it adjusts to lower monitor hz.
In that case, can I maintain 240hz performance if I run the main monitor in full screen?
I once read that if you use this combination in replication mode, a 240hz monitor will have a minus 60hz and can only provide 180hz performance.
Now it is 2025. Is this still the case in Windows 11 and Windows 10?
When broadcasting, is it correct to send it to the capture board in duplicate mode on a 240hz monitor, capture it at 60hz, and use the 240hz performance when broadcasting?
