Every time I restart my pc none of my "gamer" profiles are saved and my strobe utility settings are reset... any fix..?
When my pc boots after it is inside windows the screen turns off and on a few times going through the various profiles.. but then all of my settings reset.
xl2420z not saving settings and strobe utility
zefs
Re: xl2420z not saving settings and strobe utility
Do you have the V2 firmware? I think the settings save was a bug with V1.
jam3s121
I should have v2, bought it from amazon.com
I noticed the display pilot software was cuasing issues, i unistalled it and it stopped flipping between profiles.. but occassionally on reboots my monitor reverts to Gamer1 instead of "standard."
really stupid, wish i never bought this thing.
