Question about Gsync
Avi
Post by Avi » 30 May 2025, 04:51
When i use it on a game that is locked to 60 fps, do i need to lower my monitor refresh rate? Or do i set it in the same way i set it to other games(Gsync ON+NVCP Vsync ON+Cap fps below refresh rate). But in this case i need to cap it below 60, although the refresh rate is 240?
Re: Question about Gsync
Post by jorimt » 30 May 2025, 08:48
Avi wrote:
30 May 2025, 04:51
The minimum -3FPS limit recommendation for VRR is relative to your current physical refresh rate, thus at 240Hz, 60 FPS is already 180 frames within the refresh rate. I.E. it's a -180 FPS limit.
So no, at 240Hz 60 FPS VRR, you don't need to reduce your physical refresh rate or set a limit below 60.
