Hello, I need your help with an issue that confuses me. I switched to a laptop with a Gsync display. However, before this, I had a viewsonic freesync 144hz monitor and a case with a gtx1660 card. I noticed that on my old case, I was seeing screen tearing regardless of fps. I thought it happened when I connected the laptop to my monitor because I hadn't noticed the tearing in 4 years. However, when I looked at my old videos, there were actually screen tearing. I guess I didn't pay attention. (4 years...)
All I'm wondering is this: Is it normal for me to see screen tearing regardless of fps with (30,60,120 160fps) a freesync monitor and nvidia card that doesn't support gsync? I'm just curious about the answer to this question.
Freesync Monitor & Nvidia Gpu Tearing
sailorscenarist
Re: Freesync Monitor & Nvidia Gpu Tearing
Sorry for my English. My monitor is freesync but not gsync compatible… My graphics card is Nvidia. Is it normal to see screen tearing regardless of fps?
- jorimt
If G-SYNC is not supported and V-SYNC is disabled, yes, screen tearing is normal, regardless of FPS.sailorscenarist wrote: ↑03 Jun 2025, 12:59Sorry for my English. My monitor is freesync but not gsync compatible… My graphics card is Nvidia. Is it normal to see screen tearing regardless of fps?
sailorscenarist
Thank you much for your answer. I knew that Freesync and nvidia cards did not work, but I was wondering if it is normal to see a lot of tearing within the screen hz(1-144fps). Thank you very much.jorimt wrote: ↑03 Jun 2025, 13:52If G-SYNC is not supported and V-SYNC is disabled, yes, screen tearing is normal, regardless of FPS.sailorscenarist wrote: ↑03 Jun 2025, 12:59Sorry for my English. My monitor is freesync but not gsync compatible… My graphics card is Nvidia. Is it normal to see screen tearing regardless of fps?
- RealNC
You can force g-sync in the nvidia control panel for displays that only support freesync. But I believe this option only shows with DisplayPort, not with HDMI.sailorscenarist wrote: ↑03 Jun 2025, 14:29Thank you much for your answer. I knew that Freesync and nvidia cards did not work, but I was wondering if it is normal to see a lot of tearing within the screen hz(1-144fps). Thank you very much.
