Ok, wow… so I guess microLED is the future of displays?!?! (1 million Hz display achieved)
Ashrainstorm
Post by Ashrainstorm » 23 Jun 2025, 21:59
An article posted on Tomshardware just a few of days ago:
“X Display Company (XDC) has introduced an advanced high-speed screen that can display one million frames per second.”
“The 'display system' (or rather a TX-RX system?) is comprised of an ultrafast microLED display that acts like a transmitter and a high-frame-rate camera that acts like a receiver.”
A 1,000,000Hz capable display is incredible, but what impressed me even more is that it’s being demonstrated on a microLED display, which I had no idea could reach this level of performance. I mean, think of the implications! How impressively low must input lag, response time, and image persistence have to be for you to be able to sustain 1 million FPS? Have developments in microLED technology really come this far or do you guys think this is just a one-off? Could microLED really be the future of displays?
kyube
Re: Ok, wow… so I guess microLED is the future of displays?!?! (1 million Hz display achieved)
Post by kyube » 24 Jun 2025, 07:23
Ashrainstorm wrote:
23 Jun 2025, 21:59
The biggest blocker to benefiting from microLED's persistence target is the software overhead we're battling with.
Frame interpolation (generation) is only a band-aid for the issue we're having.
There's only so much hardware we can throw at problems...
William Sokol Erhard
Post by William Sokol Erhard » 26 Jun 2025, 15:31
LEDs of any variety but especially non-organic crystalline LEDs are capable of incredible update rates and response times.
The problem is that each LED needs to be individually placed and a 4k display require between 8.3million or more likely ~25 million LEDs to be placed precisely with a pick-and-place machine which is an expensive process for mass manufacturing.
The other issue is driving those LEDs. Running a single LED at 100 or 1000 kHz is easy, running 25 million of them at more than a couple hundred hertz is a far larger task. Synchronizing all of them at extremely high precision is another massive task.
Then you have to send that amount of information to the display from some sort of GPU or rendering device. If it takes about 40Gbps to send 4k120 at 10bit, for 1 MHz refresh rates you'll be looking at 333 terabits per second of bandwidth under perfect scaling. More realistically it'll be even more to account for additional overhead.
For context, the highest bandwidth fiber optic connection available for backbone internet infrastructure is only about 400Tbps.
https://en.wikipedia.org/wiki/Fiber-opt ... ber_cables
We're a long way off from that kind of performance is consumer hardware unfortunately. All the performance characteristics of microLED or even regular OLED mean right now is that the display panel itself is no longer the bottleneck of temporal performance.
That all is to say nothing of trying to generate 1 million frames per second. Even running pong at that rate would be an incredible undertaking.
That said, we're quickly getting kiloHertz displays and motion performance on modern OLEDs can be exceptionally good compared to anything available before.
