Is it possible to disable LFC?
hhhhhhhhhh
Post by hhhhhhhhhh » 09 Jul 2025, 05:25
Is it possible to disable LFC on nvidia GPU, without disabling DSC and limiting vrr range?
On my monitor 271qrx LFC triggers at 60 fps and causes heavy vrr flickering(it jumps from 60 to 120hz even with ideally smooth frametime).
Re: Is it possible to disable LFC?
Post by Slender » 06 Jan 2026, 20:24
nice forum
peppermintie_
Post by peppermintie_ » 05 May 2026, 05:21
hhhhhhhhhh wrote:
09 Jul 2025, 05:25
I was playing around with cru and vrr range, got it set to 61-240, then 60 fps would sit 120 with lfc almost all the time. Then i set it back to default 48-240, something bugged and lfc didnt kick in at all, below 48 fps monitor would just sit at 48 hz and 60 fps was almost perfect 60 hz, that lasted until pc restart tho. Sadly I dont know any way to disable lfc completely
