Ferrite shielding rings are completely ineffective
Sandy
Post by Sandy » 29 Jul 2025, 09:53
I bought 10 ferrite beads and used them all on my DP cable, but nothing happened. I also used the beads on the 220V power cord and even on the main power strip, but nothing worked. As long as input lag is there, it seems even God can't stop it.
Now the only thing I haven't tried is the isolation transformer
ablemor
Re: Ferrite shielding rings are completely ineffective
Post by ablemor » 29 Jul 2025, 14:38
Just buy toroid.
Sandy
Post by Sandy » 29 Jul 2025, 16:03
ablemor wrote: ↑
29 Jul 2025, 14:38
Just buy toroid.
What is a toroidal coil?
Kyousuke
Post by Kyousuke » 08 Aug 2025, 10:02
I just tried it, feeling the input lag is even worse than before. I've tried everything from voltage stabilizers to transformers to UPS, but nothing has improved. :(
Sandy
Post by Sandy » 10 Aug 2025, 11:09
Kyousuke wrote: ↑
08 Aug 2025, 10:02
Have you tried a medical grade isolation transformer? Or a double conversion UPS that runs entirely on batteries?
