Wind tribune to wind trubine for off-grid
Posted: 11 Aug 2025, 07:25
by amorou
Hehe , firstable some generators doesnt provide smoothest electricty out there so if you tried them and it was not good its not neccesarly means going off-grid wont benefit to you.
To the subject , idea is getting wind power from our home electricty than turning it to electricty.
Design of two tribunes in a pipe would be least annoying choice , it would be cheap to build and efficency wont hurt us since pc dont use a lot power.
I will look into it , maybe some of you will too.
Re: Wind tribune to wind trubine for off-grid
Posted: 11 Aug 2025, 08:41
by Slender
amorou wrote: ↑11 Aug 2025, 07:25
pure sine inverter + li-ion battery 150$, will give you the ability to disconnect from the outlet. Why not try this first to understand whether you have a problem in your outlet or in your walls?
Posted: 11 Aug 2025, 09:22
by amorou
Slender wrote: ↑11 Aug 2025, 08:41
I propose this as long term solution , batteries die , and inverters better to be expensive ones.
This method also lot cheaper in my country
Posted: 11 Aug 2025, 09:24
by Slender
amorou wrote: ↑11 Aug 2025, 09:22
I'm not talking about a permanent solution, but about a thing that will help you find out if the problem is coming from the outlet or from your walls.
Posted: 11 Aug 2025, 11:10
by amorou
Slender wrote: ↑11 Aug 2025, 09:24
Yeah you figure out first if your grid is the problem obviously
Posted: 11 Aug 2025, 11:14
by Slender
amorou wrote: ↑11 Aug 2025, 11:10
i know
Posted: 12 Aug 2025, 03:58
by Kipperii
Are there any large disposable batteries I can use to test if the problem is with the power?
