Should I be worried about 10ms input delay caused by frame generation?
Supermodel_Evelynn
Post by Supermodel_Evelynn » 15 Aug 2025, 10:46
I cannot unsee how good Street Fighter 6 looks at 120 FPS with frame generation AMD's AFMF 2.1 which has the lowest input delay of any frame gen of just 10ms lag at 60 FPS Native and 5ms lag at 120 FPS native
Seeing how smooth and clear the game looks at 120 FPS even tho locked to 60 FPS I would like to continue using this frame gen the AMD tool reports 10ms frame gen lag but I don't feel any lag
There is "lag" in the sense of you watching a 120 FPS image on screen but playing at 60 so it has this fake weighted feel to it but it's not actual lag because if I close my eyes and hit the same button and listen to the audio cue feedback I can't tell which is 10ms and which is 0ms
chocobeau
Re: Should I be worried about 10ms input delay caused by frame generation?
Post by chocobeau » 15 Aug 2025, 17:26
I don't know if it can help but try https://www.audiocheck.net/blindtests_t ... hp?time=10
