I just fixed my input lag and it won't come back
Sandy
Post by Sandy » 15 Aug 2025, 21:20
naporitan
Re: I just fixed my 50% input lag and it won't come back
Post by naporitan » 17 Aug 2025, 18:48
I have several mousepad 1. Meow ultraaceaim 2. Esport tiger 3. Aqua control speed 4. Zowie gsr and I get good gaming experience only on zowie gsr
My mouse - wlmouse ying, 1khz, 800 dpi.
naporitan
Post by naporitan » 18 Aug 2025, 00:38
For many of my mousepads, I need to set lod 0.7 mm. The thing is that the mouse sensor is like a camera and when the mouse lod is set too high, the sensor does not see the texture of the pad and therefore the micro aim disappears and the effect of low dpi appears, as well as the effect of mouse floating.
Sandy
Post by Sandy » 18 Aug 2025, 10:16
naporitan wrote:
18 Aug 2025, 00:38
I actually fixed 100% of my input lag. I couldn't believe it!
It turns out I didn't have any power system lag at all. I've gone through five monitors over the years, and the real culprit was actually a problem with my mouse and mousepad.
amorou
Post by amorou » 18 Aug 2025, 16:42
Sandy wrote:
18 Aug 2025, 10:16
naporitan wrote:
18 Aug 2025, 00:38
Sarcasm right ?
mago
Post by mago » 19 Aug 2025, 02:05
MouseTester show some diff ? between the pads
Ⓢк𝕀lŁ เ𝓢 ᵗⒺм𝕡σr𝐀𝐑Ⓨ, lά𝔾 I𝐬 F𝔬ʳ𝔢𝓿ᗴ𝔯
Sandy
Post by Sandy » 19 Aug 2025, 12:33
mago wrote:
19 Aug 2025, 02:05
Yes, I bought two mouse pads and both have terrible input lag. I'm finding it hard to choose a mouse pad now. I don't even know what brand to buy.
Post by Slender » 19 Aug 2025, 14:08
Sandy wrote:
19 Aug 2025, 12:33
mago wrote:
19 Aug 2025, 02:05
try glass, maybe skypad or what it call
mago
Post by mago » 19 Aug 2025, 18:33
maybe it will be beneficial for others to see those differnce
Sandy
Post by Sandy » 19 Aug 2025, 19:10
Slender wrote:
19 Aug 2025, 14:08
Sandy wrote:
19 Aug 2025, 12:33
mago wrote:
19 Aug 2025, 02:05
I also found that Logitech's sensor has zero latency on glass, but Logitech only has one glass mouse pad and the size is too small. There is no 450*400 size.
