Please advise me on a good Windows build.
F1zus
Post by F1zus » 28 Aug 2025, 07:10
Hi everyone. Please recommend a stable and balanced custom build of Windows 11. I've been using Atlas OS recently, but it's been running a bit slow on my computer, and it hasn't been updated for a while.
You need a build with disabled services, such as Cortana, Neirosearch, Xbox DVR, and others.
Fpsgamer
Re: Please advise me on a good Windows build.
Post by Fpsgamer » 28 Aug 2025, 07:19
F1zus wrote:
28 Aug 2025, 07:10
Why do you need a custom OS, do you have an old laptop or something ?
If not, I'd recommend doing a standard w11 and spending half an hour to remove useless stuff.
amorou
Post by amorou » 28 Aug 2025, 12:48
F1zus wrote:
28 Aug 2025, 07:10
https://www.youtube.com/watch?v=jpKIiimS9Ho
I didnt like it tho , when you change some random stuff in win10 mouse movement gets worse.
I use 1909 - 18363.1082
Edit: More detail to why i didnt like it:
You can feel less latency in games but it felt disconnected to me . Maybe at places with decent electricty it would be preferable
LaggyTyp
Post by LaggyTyp » 28 Aug 2025, 17:55
I'd just get Windows 11 24H2 and clean it up myself. Otherwise, run ReviOS and be done with it.
Post by Slender » 29 Aug 2025, 02:00
F1zus wrote:
28 Aug 2025, 07:10
windows 11 ltsc
mackalren
Post by mackalren » 29 Aug 2025, 06:42
KirbyOS is one of the things I go with when don't want to waste with windows settings etc, it's just really good feeling for me from installing.
Misha1337
Post by Misha1337 » 29 Aug 2025, 09:03
Slender wrote:
29 Aug 2025, 02:00
F1zus wrote:
28 Aug 2025, 07:10
windows 11 ltsc
I am in the same boat as OP cuz I am about to go from windows 10 to 11 and I tried windows 10 ltsc before and it's feels OFF like something is wrong there also fps is a little bit lower than normal Windows it's yes lesa bloated but idk if you also felt the same as I do
Hyote
Post by Hyote » 29 Aug 2025, 13:22
My NTLite builds with parts of my scripts applied, like disabling GameBar. I have a lot of tweaks preapplied in the NTLite .xml that keep most things compatible.
trefe
Post by trefe » 29 Aug 2025, 13:53
VainOS. What speaks in its favor is stability. The guy releases a new playbook every 1-2 weeks, for example, he just added 25h2. I'm currently using 25h2, and I'd say it's better than 24h2, I'd compare it to LTSC, maybe even better than that. I've had XOS, Kernel, Sapphire, and Kirby(otherwise fine), but none of them were as smooth and reliable. I would recommend it.
xtensei
Post by xtensei » 01 Sep 2025, 05:22
trefe wrote:
29 Aug 2025, 13:53
can you give link for that os cant find it anywhere
