Hello,
I'm using a PG27AQDP 1440p/480hz and primarily playing CS2.
I've been experiencing desync/rubber banding like lag intermittently whilst playing. I figured it was a server or a game related issue because the lag looks identical to something stemming from a connectivity issue. It looks identical to an exaggerated form of rubber banding.
I used my shadow play feature to capture the lag and when I went to watch my replay it, showed no lag happening. Which left me with the realization that it is a monitor issue.
I'm not sure where to even begin with trouble shooting. Has anyone experienced an issue like this and found a solution?
Thank you,
PG27AQDP 1440p/480hz Desync Issues
Return to “Input Lag / Display Lag / Network Lag”
Jump to
- The Main Lobby
- ↳ General — Displays, Graphics & More
- ↳ News / Rumors / Conventions
- ↳ Input Lag / Display Lag / Network Lag
- ↳ Display Comfort — Eyestrain / Headaches / Motionsick
- Everything Better Than 60Hz™
- ↳ Eliminating Motion Blur — BFI / ULMB / ELMB / DyAc / framegen / LSS / etc
- ↳ OLED Displays
- ↳ G-SYNC
- ↳ FreeSync
- ↳ Game Consoles — XBOX and PlayStation — ONE / Series S / Series X / PS5
- ↳ BENQ Zowie Tweaking — Strobe Utility / Blur Reduction / DyAc
- ↳ Display Overclocking
- The Laboratory: Display Science Section
- ↳ Test UFO Motion Tests
- ↳ Area 51: Display Science, Research & Engineering
- ↳ Software Developers / Low-Lag Code / Game Programming
- ↳ Pursuit Camera Testing of Display Motion Blur
- ↳ High Frame Rate Video (HFR, UltraHFR, 120fps, 240fps, 1000fps)
- The Cafeteria
- ↳ Offtopic Lounge
- ↳ Niche Issues Affecting Latency — Electrical, Interference, EMI, Unexpected Causes, etc.
- ↳ Forum System / Registration / Suggestions
