PG27AQDP 240hz Stuck
Posted: 25 Nov 2025, 11:06
Hello! I’ve had the PG27AQDP for a few months now and I’ve always had an issue with it mainly while playing counter strike 2. Sometimes from time to time when I change my in-game resolution the monitor will lose DP signal, and I will need to unplug the monitor and once I plug it back in it will come back with signal but then it’s stuck on 240hz the 480hz option isn’t even available. Usually just turning off the monitor and letting it sit for an hour will eventually bring back the 480hz option. No monitor settings change DSC still enabled. Ever setting that’s on/off when I’m on 480hz stays the same when stuck in 240hz. I’ve updated firmware multiple times.
7800x3d
EVGA RTX 3080 12GB
not running HDR
running default color bit
I notice when this happens if I swap to HDMI 2.1 the 480hz option is back
Do we think with 1440p 480hz on dp 1.4 we are just right at the edge of bandwidth, and the monitor sometimes has an issue pushing those numbers?
using cables provided with monitor.
It happens maybe 1-2 twice a week
7800x3d
EVGA RTX 3080 12GB
not running HDR
