Recommended Monitor for Steam Machine
BustingBlur
Post by BustingBlur » 03 Dec 2025, 09:22
Hi all,
Valve are due to release their upcoming Steam Machine in Q1 2026, I plan to buy one for my son who will be turning 10, this will be his first PC and likely service him throughout his entire teenage years, a monitor is a big part of that experience and so I turn to this forum to help me find the best!
He currently has an Xbox Series S with a MX279H (for which we use Trace Free 60, feel free to suggest the best setting!) which ticks most of my boxes except for the refresh rate and VRR/LFC support.
The Steam Machine is no powerhouse and with the limited 8GB of VRAM, I think the sensible choice is to pair it up with a 1080p monitor.
I am looking for the best motion clarity (in all that entails) whilst ensuring maximum comfort and reduced eye fatigue. This means assuming sensitivity to any and all negatives of technologies that look to improve motion clarity through techniques such as strobing.
Preferred:
  • 27" (PPI is lower for 1080p but the size feels perfect)
  • 120Hz (or can be 240Hz, as consoles/phones typically support up to 120hz, but I am open to faster, it's just that I don't think the system will be able to drive any higher in most cases given the translation layer and its CPU)
  • Built-in Speakers (desk space is limited and using headphones all the time is tiresome, the monitor will also be used for casual productivity/entertainment)
Absolutes:
  • IPS (maybe not an absolute - but strongly preferred)
  • 1080p (to limit and ensure good performance out of the Steam Machine in future games)
  • FreeSync Premium (for LFC and VRR for future games)
60Hz to 120Hz is of course going to be a meaningful upgrade by itself, but ideally I want a very good 'overdrive' performing IPS monitor along with that. Maybe I'm completely off the mark by even thinking I need an IPS, I'm open to TN panels I suppose - OLED has issues with daily-use (non gaming) from what I understand and VA suffers in motion clarity more than any other. I'm open to be educated so feel free to suggest completely different to my above requirements, just take into consideration that some of it is picked specifically to ensure no accidental 4K output which reduces framerate significantly and such, I'm trying to strike a balance of plug and play with the hardware its going to be paired up with. Looking forward to your recommendations (I'm UK based btw).
Dalek
Re: Recommended Monitor for Steam Machine
Post by Dalek » 06 Dec 2025, 10:09
BustingBlur wrote:
03 Dec 2025, 09:22
I've seen 27" at 1080p and it is not easy on the eyes.
If you're going with 1080p, stick to 24". If you want a larger monitor then I would recommend a 27" 1440p.
But given the specs announced for the steam machine, I'd say 1080p is your best bet long term. That being said, you don't mention which games he'll be playing. If your son only plays indie titles and less resource intensive games, then maybe the 1440p monitor will be a better option. If he'll play more detailed/graphical intensive games then go for 1080p.
A monitor with speakers will limit your options to much cheaper / office based monitors since gaming focused monitors tend to not have them. Most cheap monitors nowadays will go up to 75-120hz. I can't say whether the motion clarity will be amazing or not, but it should be ok, especially for the price.
Option 1: 1080p 24": https://www.currys.co.uk/products/phili ... 80649.html
Option 2: 1440p 27": https://www.currys.co.uk/products/acer- ... 85570.html
purplemelon1
Post by purplemelon1 » 56 minutes ago
BustingBlur wrote:
03 Dec 2025, 09:22
Hi all,
Preferred:
Absolutes:
For the sake of future searchers. The steam machine is the equivalent of a rtx 3060 laptop without it's features. It's like a radeon rx 6600 (non xt). If you plan on using a rx 6600 with all modern features missing in the year 2030... The display you use is probably not something you care about. The standard experience/ average will probably be hooking this thing up to $60 usd monitors or their barebones TV.
P.s. some practical advice for you personally. I really think you should wait for the ps6 to launch. That will set the value/price standard for the next decade . The closest hardware that will launch after it will be rtx 6xxx refresh in 2027. Or worst case rtx 7xxx and rdna 6 a year after. Surely by then an rtx 4060 will be $150-200 usd. Or 100 quid.
Computers are no longer for gaming. You'll have to expect to pay up. Worst case the steam machine is included in that costing around £650 off the bat. There's no reason to buy that at that price. You can install linux on any computer.
Second i know you may think strobing will just be overall worse for eye health. But it's possible that having blur is just outright worse. Like constantly trying to read a blurry whiteboard a distance away. Strobed content to above 1000hz might actually be better for eye care.
What children really need to learn to the 20 20 20 rule. Every 20 minutes look 20 feet away for 20 seconds. You can tell kids to go outside but their eyes will only get worse if they just stare at the ground or their phones in the sun not actually relaxing them. Making going outside useless or even harmfull. Second, general eye exercises to relax your eyes. Just youtube that.
