USB LATENCY ANALYZER V2
Watchdog
Post by Watchdog » 12 Dec 2025, 15:41
Someone created a powershell script that tests and checks if you are using the lowest latency USB controller of your PC. On my MOBO which is ASUS ROG STRIX B650E-F it has two USB 3.2 Type A Gen 2 ports. So I plugged my Wooting 80HE and my mouse on those two USB ports, upon checking it with the latency analyzer it shows that only one USB is working as it should. Any idea why?
https://imgur.com/a/HarVShc
ablemor
Re: USB LATENCY ANALYZER V2
Post by ablemor » 12 Dec 2025, 15:52
I don't understand you, are you asking for a USB -> CPU connection? Use the USB-C ports, those are definitely the ones.
Watchdog
Post by Watchdog » 12 Dec 2025, 18:03
ablemor wrote: ↑
12 Dec 2025, 15:52
Yes, as shown in the picture that I've sent. I am trying to reduce latency of my Wooting 80HE(like my Endgame mouse in the pic) by making sure that it doesn't go through hub/chipset connection. My Wooting 80HE is 8k polling rate, is it still 8k polling rate if I use USB-C ports to connect my Wooting?
vnb
Post by vnb » 12 Dec 2025, 21:10
Watchdog wrote: ↑
12 Dec 2025, 15:41
i got you mate. Asus Support provided this to me a while ago. I asked them for a graphic with annotations of which USBs goes to CPU and they sent this (for Asus Strix B650E-F Gaming Wifi) :
B650E-F CPU USBs.png (172.37 KiB) Viewed 8096 times
Watchdog
Post by Watchdog » 12 Dec 2025, 23:13
vnb wrote: ↑
12 Dec 2025, 21:10
Watchdog wrote: ↑
12 Dec 2025, 15:41
Thank you. You're the best man.
kyube
Post by kyube » 13 Dec 2025, 09:58
Watchdog wrote: ↑
12 Dec 2025, 15:41
All of these CPU vs PCH routed USB ports topics are trivial & frankly ridiculous to discuss.
We're talking about a <1000ns (<1µs) difference in routing between CPU vs PCH.
Chasing USB driver DPC & ISR performance are far more fruitful than this topic.
hot_coffee
Post by hot_coffee » 13 Dec 2025, 10:33
kyube wrote: ↑
13 Dec 2025, 09:58
Watchdog wrote: ↑
12 Dec 2025, 15:41
I have to disagree, it is noticable. The number may be small in theory, but if you are actually playing aim trainers and can archieve top scores, you can notice the difference immidiatly. And it is such an easy improvement by just plugging the mouse into the correct USB port instead of chasing driver latencies.
kyube
Post by kyube » 13 Dec 2025, 12:03
hot_coffee wrote: ↑
13 Dec 2025, 10:33
Human bias based on the plentiful of ignorant claims about certain settings purported online can do wonders to "boost scores" as well :)
Psychological & physiological effects play a much larger role than you & many other users around here think.
hot_coffee
Post by hot_coffee » 13 Dec 2025, 13:31
kyube wrote: ↑
13 Dec 2025, 12:03
hot_coffee wrote: ↑
13 Dec 2025, 10:33
Lmao just because you can't feel a difference, it doesn't mean others can't. Not sure if this is just ragebait or you are seriously this ignorant, every latency guide mentions this trick and that's for a reason. It seems to be a skill issue on your end.
Post by Slender » 13 Dec 2025, 13:59
kyube, if I perform an action after which I see the value 1 in the program, and I see the value 0 after I reverse the action, can I trust that program?
