I am having trouble with stuttering when moving windows (Windows 7 64-bit), looking around in shooters (3d), etc.
I have not been able to get rid of this issue whatever I tried (and I tried a lot of things).
I get "stuttering warning" when I do your test @ http://www.testufo.com/ (also it only shows 60 fps but not 120 fps ... but it should because I have a 144 hz display?!)
And then I tried this test, too:
http://www.testufo.com/#test=stutter&demo=smooth
It's not smooth but stutters and I notice tearing (it moves from top to the bottom within the white bars).
My system specs:
Hardware:
Monitor: Asus VG278h 144 hz Monitor
Betriebssystemname Microsoft Windows 7 Ultimate
Prozessor Intel(R) Core(TM) i7-2700K CPU @ 3.50GHz, 5901 MHz, 4 Kern(e), 8 logische(r) Prozessor(en)
BIOS-Version/-Datum American Megatrends Inc. F19e, 21.11.2012
SMBIOS-Version 2.7
Installierter physikalischer Speicher (RAM) 16,0 GB
Gesamter realer Speicher 16,0 GB
Verfügbarer realer Speicher 12,9 GB
Gesamter virtueller Speicher 31,9 GB
Verfügbarer virtueller Speicher 28,4 GB
Größe der Auslagerungsdatei 16,0 GB
Auslagerungsdatei C:\pagefile.sys
What can cause this stuttering?
Thank you so much for your help!
