PG27AQN with ULMB2 - what type of V-Sync should I be using to eliminate tearing?
DFL91
Post by DFL91 » 26 Dec 2025, 03:05
With a 4090 my frames are stable and I'm running the monitor at 240hz because I don't want to use DSC. But with ULMB2 you obviously can't use G-Sync at the same time. So, with Reflex on Ultra, do you just use regular V-Sync, adaptive V-Sync, or Fast V-Sync? Or maybe Scanline Sync with Rivatuner?
Just wondering which of these options would be best for lower input lag while also eliminating screen tearing.
nuninho1980
Re: PG27AQN with ULMB2 - what type of V-Sync should I be using to eliminate tearing?
Post by nuninho1980 » 09 Jan 2026, 02:45
Regular vsync is best but ULMB2 should be enabled. If you want to enable G-Sync, you should enable Pulsar (but need newest firmware for your monitor). :)
You should use Reflex. Or you enable triple buffer (TB) for vsync required but TB may degrade or damage VRAM despite non-overclock speeds, if GPU usage isn't lower than 75%.
RAM: 2x16GB DDR4@3600MHz
MB: MSI PRO Z690-A DDR4
GPU: Zotac RTX 4090 non-OC <3 :D
HDD: SATA 1TB
PSU: AEROCOOL 1kW 80+ Gold
Disly: ACER Predator XB273U F5 !NEW! :mrgreen:
twisterr
Post by twisterr » 13 Jan 2026, 14:14
i wonder the price difference, if they had used a QD backlight instead of red phosphor backlight
