I am experiencing a complete "No Signal" failure between my Desktop PC and Optoma UHZ50 projector. This setup worked perfectly in the past, but the connection degraded over time until it stopped working entirely with this specific PC.
My Setup:
Projector: Optoma UHZ50 (Firmware C15).
Soundbar: LG SN9Y (Used for HDMI passthrough).
Cabling: Two high-quality, expensive Active Fiber Optic HDMI cables (5m from PC to Soundbar, 10m from Soundbar to Projector).
PC: ASUS Prime B660M-A D4 (BIOS 3811), i5-12400, RTX 4060.
Detailed Description:
Gradual Failure: Initially, everything was perfect. Then, it started taking a few minutes for the image to appear. This "wait time" gradually increased to an hour, and now, even after two hours, there is no signal at all.
Visual Artifacts: Before the total blackout, when the image finally appeared, I noticed tiny horizontal red lines in the center and flickering red dots ("sparkles") visible mostly on black backgrounds.
Ports Tested: * I have tried both HDMI ports on the RTX 4060 - neither worked.
I have also tested both HDMI ports on the Motherboard (Onboard graphics) after updating to the latest Intel drivers - neither worked.
Importantly, the DisplayPort output on the PC works perfectly and instantly when connected to a small monitor.
The "Resolution Trick": Lowering the resolution and using "Duplicate Display" sometimes helped force a connection in the past, but even that took an hour to sync and no longer works.
Software Isolation: I even performed a clean boot using a Windows 11 "To Go" (OTG) USB drive to rule out any OS/Driver corruption, but the issue persisted.
Audio Cutouts: If I reverse the chain (PC -> Projector -> Soundbar via ARC), the image appears instantly, but I suffer from frequent audio cutouts.
Cross-Testing (The Laptop Factor): A simple work laptop connected to the exact same chain (using the same 5m cable to the Soundbar) works instantly at 4K/60Hz with no artifacts or delays. This confirms the cables, Soundbar passthrough, and Projector are 100% functional.
Troubleshooting Done:
Updated Motherboard BIOS to 3811.
Forced PCIe to Gen3.
Verified UEFI mode is active.
Any thoughts or suggestions?
please help! Gradual Signal Degradation & "No Signal" - Desktop PC to Optoma UHZ50 via LG SN9Y
Papito404040
