My journey with EMI/RFI, a list of tested fixes
felhuy
Post by felhuy » 03 Feb 2026, 22:02
This thread documents my short journey troubleshooting EMI/RFI-related issues in my PC setup. Over the last couple of weeks I sank most of my free time into it, (borderline obsessive at times…) but I’ve now reached the point of clear diminishing returns.
My main takeaway is that interference-related problems may be more common with modern hardware than many people realize, even in this forum, and they’re easy to miss unless you’ve understood the symptoms. Most will never realize. But the difference can be dramatic for both audio and display smoothness quality.
What surprised me most is how broad the contributing elements can be. Even basic changes like router Wi-Fi configuration (channel selection, transmit power etc.) produced tangible differences in my case. And nearly everyone has a router nearby, regardless of whether they live in an area with clean air and power.
I’m writing this as a PC enthusiast first. For what it’s worth, I have a PhD in EE (electromagnetics/photonics), and that mostly just helped confirm I wasn’t chasing ghosts.
I first got into latency optimization about 10 months ago, after upgrading my HW. I went down the latency-optimization rabbit hole: BIOS settings, memory timings, background processes, driver/OS tweaks, most things I knew about but hadn’t realized could matter this much in practice. A sad testament that modern consumer hardware/software is not build for latency in mind out of the box…
Months after I’d settled on what I thought was my “final” set of optimizations, I noticed, almost by accident while gaming, that routing some USB devices through simple adapters (adding an extra connection in the chain) improved visual smoothness. That didn’t make sense. I’d just added another interface and, in theory, another point of failure. My first suspicion was that I was unintentionally changing the electrical characteristics of the link, things like impedance and how much high-frequency noise can pass. This led me to diagnose a broader set of noise issues that had been heavily plugging my setup. To keep this short I’m going to switch to bullet points from here, listing all adjustments that worked. Right now, this feels like a fundamentally new experience, something I honestly didn’t think could be possible. It reminds me of gaming 10–15 years ago. But that may also be nostalgia…
  • Ferrite cores everywhere, on both ends of most cables (USB, power, display). I also added ferrites to other household devices (yes, even a toothbrush charger in the bathroom). Every single physical change was documented and tested in controlled gaming environments, and in my setup the improvements were consistent. The fact that ferrites helped on devices not even on the same outlet may suggests some degree of RFI current coupling through the home wiring. A high-end UPS may help with that, but ferrites still seem very beneficial overall.
  • Farraday fabrics, everywhere, including the PC case panels (I never liked glass panels anyway), the backs of the monitors, bookshelf speakers and amplifier, my Stream Deck, and even parts of power strips (done safely, these materials are highly conductive). The only areas that were not covered are the front and top panels of my case where mesh screens were installed for airflow, they had a similar effectiveness. I also added shielding to the wall behind my desk. Everything was installed carefully so it didn’t ruin the look of the setup. Also, I realized you have to be careful about bonding/connecting different pieces of shielding. If you tie everything together incorrectly, you can unintentionally create a return path that routes conducted noise back toward the device, basically defeating the point. It took a fair amount of trial and error to get the grounding/bonding strategy right, but once I did, the results were noticeably better. You want them to act as shields, like a faraday cage.
  • Ferrite rods & toroids. On top of the usual clamp-on ferrites, I tried those cheap antenna ferrite rods/toroids (a few bucks each on AliExpress). I dropped them in “hot spots” where cable bundles and shielding fabric pass close together, and stacked a few on the speakers. My intuition is they act as dissipators for RF currents passing through the shields, the same way cores do for wires. Perhaps these would not be needed if I did proper grounding/bonding everywhere, but that’s a whole project on its own. Arranging a few rods and regular ferrite clamps INSIDE the case also brought improvements
  • Sleeving cables and building pre-shielded ones. You’ll see people online claim shielded Ethernet is “a waste of money,” but that could not be further from the truth, buy one, even if it’s only for peace of mind. I did an exhaustive test with the shielded and unshielded one and the change was very noticeable when I knew where to look. A lot of people simply have no idea how to notice interference issues. Audiophiles know.
  • Wi-Fi tweaks (last step). I suspected most of the noise was coming from outside (I’m in urban LA), but in-home RF can absolutely add to the mess. I’m obviously not going to unplug a fridge for latency gains in a competitive FPS, but I did end up dialing my router’s transmit power down to 10%, shielding the router and simplifying the 2.4 GHz settings: G-only, channel 1, 20 MHz bandwidth, WPS off. Yeah, that’s “suboptimal” on paper, but in my apartment, Wi-Fi is basically just for smart lights/vacuums.
Overall, I’m very satisfied with the results. I moved into this apartment about 2.5 years ago and I’ll probably move again soon, these tweaks will be the first thing I repeat in the new place. And now when I lose in competitive games, I can finally blame myself instead of my setup. The difference really was that big. Enjoying high quality audio and perfect smoothness in desktop is a huge added bonus.
Sirkiwi
Re: My journey with EMI/RFI, a list of tested fixes
Post by Sirkiwi » 04 Feb 2026, 15:51
Thanks for sharing your experience.
I've been learning about interference reduction techniques from a ham radio friend, and I learned about "common-mode noise," which apparently plays a significant role in EMI/RFI problems.
I recommend trying ferrite cores mix-31 and mix-43. Use them with an extension cable and wrap it around each core about six times. This has given me better results than an online UPS.
Sorry for my English
akylen
Post by akylen » 04 Feb 2026, 22:38
Sirkiwi wrote:
04 Feb 2026, 15:51
Do you have any picture to demonstrate please ?
Cosmostraveler
Post by Cosmostraveler » 05 Feb 2026, 00:26
felhuy wrote:
03 Feb 2026, 22:02
Can we get some more explanations on tweaking he WiFi settings?
I know there is an app for your phone (most likely PC as well) to test how many routers are near you and on which channels (so you can change them manually for best performance).
https://www.reddit.com/r/LogitechG/comm ... erference/
This can also possibly help some folks, I know someone was hearing the static buzz and once he changed channels in his router settings it stopped.
spkii
Post by spkii » 05 Feb 2026, 07:23
felhuy wrote:
03 Feb 2026, 22:02
Which measure would you say has been the most helpful? Ive tried ferrites in all cables too, have actually all connected to UPS. Do you have some photos of your setup actually?
felhuy
Post by felhuy » 05 Feb 2026, 20:30
With the Wi-Fi the idea was to attenuate its output power and emission events so kind of the reverse process you would follow by optimizing based on empty channels, etc. Have it in the most bare bones state for my needs without missing 99% of its functionality relevant to me. I live in an apartment complex with dozens of active routers nearby, it is really a messy environment.
The most effective measure I would say was the Faraday fabrics, once placed properly.
spkii
Post by spkii » 06 Feb 2026, 04:59
felhuy wrote:
05 Feb 2026, 20:30
For me, add more Ferrites to cables do it worse (more heavy feeling), maybe cause all is connected to an Salicru SLC Twin Pro 2 1500VA Schuko SAI. Idk how to test with faraday, maybe some faraday cage test would work? But only on computer not display.
astroasis
Post by astroasis » 06 Feb 2026, 08:19
Funnily enough I had better results putting ferrite clamps inside the PC case on the gpu connector just before it goes in and the 24 pin atx, on the cables didnt do much, im also going to try the mix 31 and 43 as recommended here
felhuy
Post by felhuy » 06 Feb 2026, 17:25
As an update, I followed Sirkiwi advice and tied my main power cable (going to my power strip) multiple times around a core and had much better results than a single clamp-on ferrite. I did the same with my display cables also seeing a nice improvement. There has to be a maximum area needed for maximal RF dissipation, I suppose a small clamp-on ferrite was not enough in my case.
astroasis wrote:
06 Feb 2026, 08:19
Yes, this is a good advice, it helps
astroasis
Post by astroasis » 07 Feb 2026, 12:27
Waiting for my toroid cores to arrive to test. Another thing that gave me huge improvement today was unplugging everything from my front usb ports on my pc and only using the back, and unplugging my USB audio dac which i used to play guitar with, although not sure if these improvements are from the ferrites or not
