MPO - Off
Panychkaaa
MPO - Off
Post by Panychkaaa » 09 Feb 2026, 02:52
Regedit:
- HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\GraphicsDrivers
- "DisableOverlays"=dword:00000001
Work: Last OS :geek:
Info: https://www.reddit.com/r/AMDHelp/commen ... _solution/
Re: MPO - Off
Post by Slender » 10 Feb 2026, 18:45
thanks little princes
Apexer15
Re: MPO - Off
Post by Apexer15 » 18 May 2026, 12:46
Tried that and it gave me more input lag for some reason. Anyone knows if that's normal?
I'm not talking about EMI input lag that's something I have since many years ago but it increased the normal input lag (sluggish and slow feeling like if my controller is moving in the mud). When I removed the value from the registry edit and restart, the normal input lag is gone and the EMI input lag (desync /bad hit reg... Etc) stayed.
Panychkaaa
Re: MPO - Off
Post by Panychkaaa » 18 May 2026, 14:20
Apexer15 wrote: ↑
18 May 2026, 12:46
I do not recommend using these settings. This is for testing.
This does not help with delays.
naporitan
Re: MPO - Off
Post by naporitan » 18 May 2026, 19:17
I have an msi rtx 3090 suprim x 24gb and when I turn off the mpo, I get strange problems with the monitor flickering in the browser.
faust123
Re: MPO - Off
Post by faust123 » 19 May 2026, 11:39
w11 25h2 works in cs2 only with disable fullscreen optimisation checked.
Watchdog
Re: MPO - Off
Post by Watchdog » 24 May 2026, 05:08
faust123 wrote: ↑
19 May 2026, 11:39
Same. Not only in CS2 but all applications flicker when I am on fullscreen, I have to tick the disable fullscreen on compatibility tab every time. I tried disabling FSO on regedit to do it globally but it doesn't work, only the compatibility tab works. Do you guys have a workaround?
