CS2 RAM Timing HELP pls
Posted: 14 Feb 2026, 00:29
Hi guys, in this post (viewtopic.php?t=15265 ) I described my issue along with my PC and equipment specs. In the end, it turned out that the problem was not related to scaling.
Now I’m opening this topic in hopes that someone can help me with RAM timings, since I’ve heard they are very important for CS2. Even if they don’t fix the issue, maybe they can at least improve overall game performance.
These are my current timings - default EXPO1 profile.
https://imgur.com/ZH2RbQI (sry idk why img not showing)
My RAM: Kingston DDR5 16GB 6000MHz CL30 (2x16GB).
I need someone knowledgeable to tell me whether these timings (and everything shown in the screenshot) are correct, or if something should be changed. If changes are recommended, which timings should I try adjusting?
My PC:
CPU: AMD Ryzen 7 9800X3D
GPU: NVIDIA GeForce RTX 4070 Ti SUPER 16GB
Motherboard: MSI MAG B850 TOMAHAWK MAX WIFI
PSU: Lian Li 1200W Edge 80PLUS Gold (PCIe 5.1, ATX 3.1, USB Hub)
SSD: Samsung M.2 NVMe 9100 PRO Series 1TB
My PC:
