OLED vs fast IPS with nvidia pulsar
mcnabb05
Post by mcnabb05 » 19 Feb 2026, 22:57
I bought the pulsar monitor, but thinking about returning it since i don't really notice a difference between pulsar on vs off in competitive games. Is OLED a big upgrade to this thing when it comes to competitive games? I never had an OLED before and i really don't want to have to worry about burn-in and deal with warranty replacement etc. Does anyone have both this and a high refresh rate OLED that can help? I play marvel rivals/overwatch/the finals, is there a big difference in those kinds of games compared to the pulsar monitor? Is the latency noticeably lower in games? Thnx
Re: OLED vs fast IPS with nvidia pulsar
Post by RealNC » 20 Feb 2026, 05:48
mcnabb05 wrote: ↑
19 Feb 2026, 22:57
At high FPS, yes. 480Hz/480FPS on OLED looks very clear. Note though that if you use VRR, OLED is really bad at it (heavy flicker.)
No. There are no differences in latency whatsoever.
kyube
Post by kyube » 21 Feb 2026, 07:38
mcnabb05 wrote: ↑
19 Feb 2026, 22:57
-snip-
500Hz QD-OLED (FO27Q5P, AG276QKD2 or 271QR X50) or a good backlight strobing model (e.g.: XL2566K)
Pulsar is mediocre, at best.
RealNC wrote: ↑
20 Feb 2026, 05:48
Between a Pulsar enabled model & a OLED model? There absolutely is
mcnabb05
Post by mcnabb05 » 21 Feb 2026, 16:10
kyube wrote: ↑
21 Feb 2026, 07:38
mcnabb05 wrote: ↑
19 Feb 2026, 22:57
-snip-
RealNC wrote: ↑
20 Feb 2026, 05:48
what if i used ulmb on games with 360+ fps? would that make it more viable and closer to those models? or is that also crap on this thing?
kyube
Post by kyube » 21 Feb 2026, 17:55
mcnabb05 wrote: ↑
21 Feb 2026, 16:10
Pulsar models are simply bad for fixed refresh rate strobing.
Opt for ASUS PG27AQN instead, if you want to chase down that path.
360Hz @ PW=100 (25% duty cycle; 272cd/m²) would get you ”effective ~1440Hz refresh rate”
[steps in between, increments of 10]
360Hz @ PW=10 (4,5% duty cycle; 24cd/m²; lowest setting) would get you ”effective ~8000 Hz refresh rate”
Source of data: https://tftcentral.co.uk/reviews/asus-rog-swift-pg27aqn & extrapolation.
The PG27AQN with it's adjustable PW eclipses the Pulsar models by quite a large margin
mcnabb05
Post by mcnabb05 » 21 Feb 2026, 18:32
kyube wrote: ↑
21 Feb 2026, 17:55
mcnabb05 wrote: ↑
21 Feb 2026, 16:10
Damn, so there is literally no use case for this thing? I figured since most the games I enjoy run in the 200-300 fps range this thing would be perfect for that
Also, do you think they will add a pulse width slider in future firmware updates?
