XG248QSG vs XL2566X+
Posted: 22 Feb 2026, 15:57
by Watchdog
Is XL2566X+ better than XG248QSG in terms of motion clarity considering DyAc 2/ELMB2 are enabled on each monitor?
I am using XL2411K at the moment. I am willing to sacrifice a little bit of motion clarity for more clearer image because I tend to lose the crosshair at my targets when tracking them. Like my eyes lose track of them so it's harder for me to track them for a longer period of time. It's also a bit harder for me to spot enemies from far away. I have my monitor a little bit away from me as I am comfortable with it but if I move it a little closer, I sacrifice my reflexes/aim.
Re: XG248QSG vs XL2566X+
Posted: 22 Feb 2026, 17:59
by kyube
Watchdog wrote: ↑
22 Feb 2026, 15:57
You're not going to see a major improvement over a XL2411K with DyAc enabled (tuned with Blurbusters utility for the best possible MPRT value)
I can give you the exact values of the ASUS XG248QSG settings, namely:
It has 5 distinct “Clarity Level” settings, each of which targets a specific (fixed) duty cycle:
Lvl=1 → 72%; Lvl=2 → 53%; Lvl=3 → 42; Lvl=4 → 27; Lvl=5 → 20%
Source of data @ 03:20
What does this mean in practice?
Let's assume you can run FPS=Hz constantly (meaning 600FPS @ 600Hz; t= 1,6667 ms ), you're looking at:
1.2 ms 'on' period (“833 Hz effective motion clarity”) @ 424 cd/m²
0.88333 ms (“1132,075 Hz effective motion clarity”) @ 409 cd/m²
0.7 ms (“1428,571 Hz effective motion clarity”) @ 384 cd/m²
0.45 ms (“2222,22 Hz effective motion clarity”) @ 335 cd/m²
0.333ms (“3 000,003 Hz effective motion clarity”) @ 290 cd/m²
This is how the performance of the XG248QSG would be.
The display works on these refresh rates (I assume a custom res would also work, but I'll stick to review data & manual):
100, 120, 240, 360, 500, 600, 610 Hz
The lower the refresh rate, the lower the total clarity benefits.
You must ensure FRate>RRate to achieve the least amount of "phase shift"-like aliasing, which occurs when FRate<RRate
I don't know whether the pulse behavior changes depending on the refresh rate, as reviewers aren't willing to test displays to this type of depth.
Now, for the XL2586X+:
You have 2 distinct fixed duty cycle settings: DyAc High & DyAc Premium (the better clarity setting)
My assumption (I have no data for this specific model) is that they target a PW of ~40%, which would bring it to a lower “effective motion clarity” than the ASUS model above.
Note that this value mentioned above is likely extremely higher than what BenQ/Zowie are using in practice
The only public source I've come across is this one, which claims a “1836–3109Hz effective motion clarity
This would mean that DyAc=Premium targets a pulse width of 19–32% (which would bring it on-par or slightly worse than the ASUS, depending on exact values, in terms of effective motion clarity it targets)
The BenQ models (86X & 86X+) are the only models on the market to sport a QD-based backlight, which means no red fringing will occur.
The ASUS is a KSF/PFS based model.
The only other model I've seen which eclipse both completely is the PG27AQN with its ULMB2 mode, which is able to do ~3% pulse width at ~20cd/m²... :D
Sadly KSF fringing is present & I don't know what effective motion clarity you can achieve @ ~100cd/m².
To be specific, CRTs have “+4000 Hz effective refresh rate” across the usual 60–200Hz that they used to come in.
That's the benchmark of every strobing implementation IMO.
I don't know how the XL2411K behaves, as you have the option to use the Blurbusters utility and you might like this far more than red fringing of the ASUS or the limitations of aforementioned models.
I'm very certain that you aren't going to be achieving that clarity I've mentioned above, as you'd need an absurdly short pulse width to be able to compete.
Not only that, since brightness is inversely proportional (you're 'hiding' part of the transitions when strobing), you're going to be losing a ton of brightness.
A 10% duty cycle on your XL2411K (@ 144Hz) would get you 0.833333 ms MPRT, where you'd have much lower brightness capabilities than the ASUS above. Let's assume the XL2411K is voltage-boosting to ~1000cd/m².
You're looking at ~100cd/m² at 10% duty cycle.
5% duty would get you to 0,41666 ms MPRT, but 50 cd/m².
I assume you've understood the constraints & how this topic functions.
Yes, there are models which target a lower effective motion clarity than the BenQ & ASUS models above at a lower native refresh rate (e.g.: 360Hz with a 0,125ms MPRT and relatively usable brightness)
Posted: 22 Feb 2026, 18:17
by Watchdog
I've read your reply many times and I'm a bit lost. But thank you so much for a well-written post. I will keep coming back to it and keep reading it. I just won a world online tournament with my XL2411K and I feel like I could do more at that tournament if I could see the targets clearly even if I sacrifice a little bit of motion clarity.
Do you think you can help me which one should I get out of the 2 monitors? Or are there far better options at that price range?
Posted: 22 Feb 2026, 18:19
by kyube
Watchdog wrote: ↑
22 Feb 2026, 18:17
Let's try it from this perspective:
What are your HW components & the game you want to play? From here, we can extrapolate what can net you a competitive advantage :D
If you have a more specific question, feel free to ask.
Posted: 22 Feb 2026, 18:25
by Watchdog
I have a Ryzen 7 9800X3D and RTX 5070. I have never tried 2k/4k resolution monitors because I don't wanna get used to them because I might not be able to go back to my 1080p monitor. Yes it is clearer image but the FPS would just tank. I am thinking of getting a better 1080p monitor but clearer image than my 1080p XL2411K with not so much sacrificing the motion clarity. I don't know if that is possible.
Posted: 22 Feb 2026, 18:38
by kyube
Watchdog wrote: ↑
22 Feb 2026, 18:25
“A clearer image” is a bit ambiguous.
Static or dynamic clarity?
If former — get a screen protector to alleviate the horrible panel coating & maybe experiment with a higher brightness setting (I don't know how you've set-up your XL2411K or whether you're aware of the Blurbusters Utility)
A higher display resolution (increased pixel density) also leads to a “clearer” image.
If the latter — depends on above.
Posted: 22 Feb 2026, 18:52
by Watchdog
Better clarity like looking around trying to spot enemies, I don't know what you call it though. I am using the Blurbusters Utility with Premium DyAc and cranked it up to the brighter screen side. I already maxed the brightness and feel like it's not enough.
Posted: 22 Feb 2026, 23:25
by kyube
Watchdog wrote: ↑
22 Feb 2026, 18:52
You can measure your current brightness level by using, this video can help with that: https://youtu.be/avJTz1JhkR4?si=VQIp9vhMjWbSAEM6&t=410
I suggest applying a screen protector, you might like it: https://viascreens.com/screen-protector ... 411k/vivid
Posted: 23 Feb 2026, 02:00
by Watchdog
kyube wrote: ↑
22 Feb 2026, 23:25
Watchdog wrote: ↑
22 Feb 2026, 18:52
I did this with Blurbusters Utility already, it is still not enough brightness. About the screen protector is a no-go because I live in Asia and I don't think they can ship it there.
What are the pros and cons if I get a better monitor instead with higher refresh rate like XG248QSG or XL2566X+? Which one do you think has a better image clarity when trying to spot enemies while moving your camera around since the game is 3rd person shooter?
Posted: 24 Feb 2026, 05:13
by Watchdog
Or should I wait for 1080p monitor that has Pulsar instead?
