Unofficial ASUS XG27JCG 5k 180hz thread
Posted: 24 Feb 2026, 03:35
by purplemelon1
I am making this thread only because it is a rare 5k display. However I may focus on elmb 2. I have not found any dedicated thread for elmb 2.
Is it fine to assume elmb 2 on this display would behave the same as on the ASUS ROG Strix XG27ACS? https://www.rtings.com/monitor/reviews/ ... ix-xg27acs
Image level 5 strobing (the heaviest preset) seems to 10x persistence.
Level 1 is a 3x boost in persistence.
Now I know it does not look pleasant to some of you. To me it just looks like slight chromatic aberration no different than qd oleds. From a zoomed out perspective.
A 2880p 1800hz (or atleast 1200hz) persistence display was not on my list of possibilities
Re: Unofficial ASUS XG27JCG 5k 180hz thread
Posted: 24 Feb 2026, 06:28
by kyube
Based on chimolog's data
The Clarity_Level=5 setting seems to be ~10% pulse width, leading to ~0.55 ms MPRT @ 180Hz @ 86 cd/m²
The Clarity_Level=3 setting seems to be ~20% pulse width, leading to ~1,111 ms MPRT @ 180Hz @ 128 cd/m²
The Clarity_Level=1 setting seems to be ~30% pulse width, leading to ~1,666 ms MPRT @ 180Hz @ 253 cd/m²
The XG27ACS uses standard global scan backlight strobing. Sadly limited by the use of KSF/PFS...
I haven't been able to scout the duty cycle behavior of the XG27JCG.
This model is using (discrete) rolling scanning backlights (ELMB2) as opposed to global scan backlight strobing (ELMB1)
The saddest part is, I don't expect any of the alternatives (MSI 271KRAW16, AOC AGP277KX, LG 27GM950B, ACER XV270X P) to have a backlight strobing mode which is even remotely close to the XG27JCG, since most manifacturers prefer to keep it to a fixed duty cycle experience and choose brightness over MPRT.
Maybe ULMB2 on the new MiniLED Pulsars (e.g.: Acer XB323QX) might compete, assuming they implement a separate toggle for ULMB2 and allow for adjustable PW this time around....
Here's some OSRTT data of the XG27JCG @ 24:41
Here are pursuit photographs of the XG27JCG, when using ELMB 2 @ 180Hz
EDIT:
I've come across the behavior of XG27JCG's ELMB2 implementation.
Disclaimer: None of the data below is 100% accurate, treat all of this with a large grain of salt.
From this image above, we can assess the following:
Lvl=5 → 18.75% – 17.64% duty cycle
Lvl=4 → 31.25% – 29.4% duty cycle
Lvl=3 → 37.5% – 35.03% duty cycle
Lvl=2 → 50% – 47.05% duty cycle
Lvl=1 → ~56.25% duty cycle
f= 180Hz (t= 5,555555555555556 ms)
Based on this, for the XG27JCG:
The Clarity_Level=5 setting seems to be ~18% pulse width, leading to ~1ms MPRT @ 180Hz @ ~220cd/m² (assume 0.05 fluctuations; as this is a very rough estimation based on the pulse graph above)
The Clarity_Level=3 setting seems to be ~36% pulse width, leading to ~2ms MPRT @ 180Hz @ ~400cd/m²
The Clarity_Level=1 setting seems to be ~56.25% pulse width, leading to ~3,125ms MPRT @ 180Hz @ >400cd/m²
Note: The luminance values are likely wrong, the strobe 'on' period should be roughly accurate.
TL;DR: It isn't as clear as the XG27ACS, but it's mighty good for a rolling scan implementation and the density it targets.
EDIT2 from the future:
Based on iMartz video, whose TestUFO pursuit photographs are 960 px/s it's more likely that the Clarity_Level=5 setting is targeting a 35–37,5% pulse width instead... which would make it very mediocre...
Here's the ELMB2 pursuit photograph
Namely:
180 Hz (5,555556 ms) → 1,944446 – 2,083333 ms pulse on interval (480–514 Hz effective moton clarity)
The 330 Hz mode doesnt seem to align well with the aforementioned duty cycle value, as it's seemingly ≤35% (the UFO is too slow to evaluate the end region)
That's sad... it had potential.
Let's hope that the GB or MSI 27" 5K model will eclipse it, as I know that the LG model also has a mediocre duty cycle target.
EDIT3 from the future
RTINGS recently made a review of both the LG 27GM950B & the XG27JCG
RTINGS pursuit photograph uses a 1920 px/s pixel speed.
The results are grim.
Here's the LG 27GM950-B
Here's the ASUS XG27JCG @ 180 Hz (Clarity_Level 5)
& here's the 330 Hz mode:
As per RTINGS data, the XG27JCG targets ~226 cd/m² on 'Clarity Level 5'.
This, along with the 1920px/s pursuit photograph, leads me to believe the duty cycle lies within the 27-35% range.
LG targets 633 cd/m² when MBR is enabled, in comparison, while achieving similar clarity....
ASUS, why? Why are you foregoing ELMB on majority of your panels?...
According to TFTCentral
The LG uses a ~33% pulse width at the 165 Hz setting, leading to a effective motion clarity of ~480 Hz
That's a very subpar target to chase, making the implementation borderline useless... but still better than the ASUS due to lack of KSF fringing
The fact that the LG does 633 cd/m² when MBR is enabled makes their choice of not targeting a lower pulse width (<20%) even more bizarre.
The ASUS looks worse than the LG, therefore making the feature even more redundant.
A big limitation of the LG model is that MBR is only available in the 5K image resolution mode. Not in the QHD mode.
ASUS is free from this limitation...
I guess we'll have to wait for Titan Army or AOC to do a good job on these 27" 5K panels in terms of pulse width... what a dreadful market.
Posted: 26 Feb 2026, 12:26
by civic
Any problems with backlight bleed/leakage?
Posted: 31 Mar 2026, 20:45
by Dalek
This looks like a very ideal monitor to have, especially for the price. I just wish the 1440p dual mode had 500hz and not a bizarre 330hz.
Also, I don't understand why it's taken ASUS (or really any manufacturer out there) this long to make a sensible dual mode resolution. Their previous dual mode monitors go down to 1080p on a 27" sized screen which makes no sense.
Posted: 06 Jul 2026, 13:32
by purplemelon1
kyube wrote: ↑
24 Feb 2026, 06:28
purplemelon1 wrote: ↑
24 Feb 2026, 03:35
EDIT:
Namely:
Geez you are really dedicated. Thanks for the info. Atleast it's enough to be a nice bonus even if not a reason to get the monitor. Also I had no idea the system pings the quoted every time theres an edit. Whoops
Posted: 06 Jul 2026, 16:58
by kyube
06 Jul 2026, 13:32
Lol, didn't know that either.
My bad then :D
Posted: 04 Aug 2026, 10:22
by dabooga
Waiting for the Acer Predator XB323QX
Posted: 05 Aug 2026, 14:59
by Dalek
Also worth noting, there's an ASUS ROG Strix XG27JCEG 27” 5K 80Hz / QHD 360Hz Dual Mode IPS Monitor that will be released shortly too, it's £230 cheaper.
But a much lower refresh rate at 5K. Probably the cheapest 5K monitor to date I think?
Posted: 12 Aug 2026, 18:46
by purplemelon1
Small record for the thread. MSI cancelled their mini led glossy 5k 180hz screen. I wouldn't be surprised if tests showed that kind of buyer would just get the apple pro xdr 5k 120hz instead
Posted: 13 Aug 2026, 14:13
by kyube
12 Aug 2026, 18:46
That specific Apple product costs >3x more than the LG and >4x more than the XG27JCG. Not worth in the slightest.
Let's hope that Gigabyte will release their FM275K16P.
