ROG Strix XG248QSG Ace Discussion
pgz
Post by pgz » 18 Mar 2026, 18:49
Can someone break down this monitor? For some reason I am having a terrible time trying to find the correct information I want on this monitor. There are barely any posts even on this forum about it.
ELMB 2 = Is this ULMB 2 with just Asus naming it something else? Or is ELMB 2 actually something completely different? If so, how is it different from ULMB
ELMB-Sync = What is this? Is this the same as Nvidia Pulsar? Is this using ELMB 1 or ELMB 2?
Is there any information if ELMB 2 is better than Nvidia Pulsar when it comes to clarity?
MSIfanboy
Re: ROG Strix XG248QSG Ace Discussion
Post by MSIfanboy » 20 Mar 2026, 17:49
pgz wrote: ↑
18 Mar 2026, 18:49
ELMB SYNC is useless, makes no difference, i tried adjusting the fps, in smoothfrog, it just gets blurry below max hz, elmb2 has 5 levels, 5 is the best, but darker, pure speed, its slightly faster than zowie, its strobing is alright at 610-360hz, but it begins to fall off, 240hz is alright, but i find zowie is just better, a higher oled like 500hz-540hz will be faster than all in terms of input lag, elmb2 is asus strobing, i guess they didnt want to pay nvidia for the licensing/cost, i would probably get pg248qp over this monitor
Screenshot 2026-03-21 094750.png (526.67 KiB) Viewed 5767 times
