⚡eSports monitors and their secrets⚡
naporitan
Post by naporitan » 25 Mar 2026, 22:50
⚡Potential fix for desync, input lag, floaty mouse, heavy car bug, etc.⚡
viewtopic.php?t=15638
ATTENTION!
I was informed that there are older revisions of the CS24A/P that also have older scaler and firmware!!!
I do not recommend purchasing this monitor due to issues with the revision!!!
older rev cs24a_p.jpg (567.19 KiB) Viewed 12297 times
Hi everyone, I bought a new CS24A 600hz monitor and I'm sharing some interesting things I saw.
In the monitor settings, I select "image ratio" Full (Square) and after applying 1280x960 it becomes native, this is the first time I've seen this :)
naporitan wrote: ↑
26 Mar 2026, 08:51
:!: I do not recommend purchasing this monitor, as there are other revisions that have a completely different scaler and firmware.
:!: I highly recommend purchasing the CS24A/P model, as it comes with the latest firmware and scaler!
viewtopic.php?p=123688#p123688
Just in case, I didn't use CRU, etc.
faust123
Re: AGON CS24A Low input lag!!!
Post by faust123 » 26 Mar 2026, 06:40
Hi there!
I have same monitor, but idk why I cant change aspect ratio. Setting is just greyed. When I play cs even at 1280x960 monitor osd report what current image res is 1920x1080. Can you please give some more info about your setup: gpu, display port wire, and current osd settings.
naporitan
Post by naporitan » 26 Mar 2026, 08:28
faust123 wrote: ↑
26 Mar 2026, 06:40
Hi there!
rtx 3090 suprim x 24gb / dp cable from the box
naporitan
Post by naporitan » 26 Mar 2026, 08:51
CS24A
Newer rev! good scaler and firmware
CS24A
older rev - 2025.07
In this revision, you won't get a scaling display at 1280x960 resolution, etc.
older rev - 2025.08
naporitan
Re: AGON CS24A Low input lag!!! (New Rev.)
Post by naporitan » 27 Mar 2026, 05:17
naporitan
Post by naporitan » 27 Mar 2026, 05:24
UPD: 26.07.2026
viewtopic.php?p=123680#p123688
These screenshots are no longer relevant, please refer to this message for the latest information.
naporitan
Re: AGON CS24A (only newer rev) | CS24A/P | eSports scaler!!!
Post by naporitan » 28 Mar 2026, 05:16
ATTENTION!
older rev cs24a_p.jpg (567.19 KiB) Viewed 12309 times
naporitan
Re: AGON CS24A (only newer rev) / CS24A/P (only newer rev) | eSports scaler!!!
Post by naporitan » 30 Mar 2026, 04:28
UPDATED: 26.07.2026
Connecting devices on the ASRock B650 PG Lightning motherboard:
The first port for the mouse is connected to the processor through the ASMEDIA controller, and the second port is connected directly to the chipset, so you should connect the keyboard to it, and you will have to give up all other USB devices because these devices will interfere with interrupts, etc. Connect the headphones via mini jack.
Also, do not connect anything using Type-C.
Some information: If you want to stream, then you need to purchase a PCIe capture card. Do you also want to connect a USB microphone and webcam? Then you also need to purchase an external PCIe USB controller.
B650 PG Lightning(L6).png (972 KiB) Viewed 10730 times
Post by Slender » 30 Mar 2026, 05:15
naporitan wrote: ↑
25 Mar 2026, 22:50
ATTENTION!
In the monitor settings, I enable the OverClock mode and after MBR+ I set it to 0, since this is an analogue of BFI/DyaC; my eyes just start to hurt from this technology.
naporitan wrote: ↑
26 Mar 2026, 08:51
You would have realized this sooner if you'd listened to me. I've told you repeatedly that there are custom resolutions for DisplayScaling that the manufacturer sets in the monitor itself.
naporitan
Post by naporitan » 30 Mar 2026, 06:45
Locked
