Unusual ghosting on a G-Sync laptop
Posted: 17 Apr 2026, 01:10
by Katzenwerfer_MX
I’m hoping to get some insight into an issue I’ve been having with my G-Sync laptop. I've been using this machine for a while, but a few months ago, I started noticing some strange graphical artifacts.
The problem is that these artifacts appear under very specific, yet seemingly disconnected, scenarios. I have been trying to find a pattern or any coherence between them, but I haven't had much luck so far.
Here are the scenarios I've identified:
  • LSFG: When using Lossless Scaling Frame Generation with G-Sync enabled for the game, plus G-Sync compatibility enabled in the application settings, I get these specific artifacts. However, if I disable G-Sync specifically for that game, the issue goes away.
  • Unity Engine Games: I see similar artifacts in games like PEAK and GTFO whenever the game stutters badly. GTFO is a particularly good example to reproduce this, as it suffers from some poor frame pacing issues.
I’ve also noticed a very particular behavior depending on the display's refresh rate: The artifacts appear when the frame rate is inside the G-Sync range, but only before LFC (Low Framerate Compensation) kicks in. Once the frame rate drops low enough for LFC to engage, the artifacts disappear.
At first, I was worried this might be a physical hardware issue, but at some points I discovered that I can capture the artifacts in screenshots and video recordings. Hence, I’m fairly certain it isn't a hardware issue, and instead I suspect this is a software problem.
Has anyone experienced this before? Any insight would be appreciated.
Re: Unusual ghosting on a G-Sync laptop
Posted: 17 Apr 2026, 02:11
by Katzenwerfer_MX
Here is a recording and a couple screenshots of the artifacts I've described:
reference
artifacts
Posted: 04 May 2026, 09:45
by Katzenwerfer_MX
After further evaluation, I found that what I show in my recordings is a separate issue from what I'm perceiving in the display, though they have a correlation around the driver versions where both started to occur. I'll do further testing to narrow down the exact version. Hopefully I can figure out where to report this to NVIDIA, as I've found other posts on Reddit reporting similar findings.
Posted: 19 Jun 2026, 07:01
by Katzenwerfer_MX
Found the issue first appeared in driver version 531.41, with all subsequent versions still being affected.
I reported it to NVIDIA through the feedback form and copied some of the details into a thread on their forums.
https://www.nvidia.com/en-us/geforce/fo ... ecordings/
