Pivoting from 1440p/320Hz to a Pure Esports monitor
Posted: 29 Apr 2026, 08:53
I’m currently using a KTC H27E6 (27", 1440p, 320Hz IPS). It’s okay, but I want to switch to a pure esports setup. I prefer the 24-25-inch size and want the best motion clarity possible for games like Valorant, CS2 etc.
My Budget: Around £350 – £400.
I’m stuck between these options and need to know which is the biggest competitive jump:
Acer Nitro XV242F: The price is great for the speed, but is the pixel response time actually good enough to keep up with 540Hz? I'm worried about overshoot or blur.
Zowie XL2566K vs. XL2566X+: Is it worth getting a used 360Hz Zowie for DyAc+, or should I save up for the newer XL2566X+ with DyAc 2? It's difficult to find good deals for both new and used.
Older Zowie XL2546K or Zowie XL2540X+: Is the motion clarity on an older Zowie with DyAc still better than "raw" 540Hz on a budget panel?
Budget OLEDs: I’ve seen the talks about OLEDs being great for response times etc. Does the 0.03ms response time of OLED beat out TN panels for pure competitive play?
PC Specs: RTX 4070 - 7800x3d - DDR5-6000-CL36
