Sony INZONE M10S II Oled with pulsar/crt simulation
LutaKura
Sony INZONE M10S II Oled with rolling scan bfi?
Post by LutaKura » 06 Jun 2026, 13:43
The new Sony INZONE M10S II Oled seems to behave similarly to pulsar with their motion blur reduction feature, it doesn't decrease brightness and seems to work with G-sync(EDIT: it doesn't), perhaps it has the mediatek gsync chip?
There is a japanese Review if you are interested
EDIT: It seems to be rolling scan bfi that doesn't affect brightness, still can't be used with VRR or Gsync
early review.JPG (80.1 KiB) Viewed 1926 times
oled pulsar?
oled pulsar?
oled bfi.JPG (61.99 KiB) Viewed 1928 times
MSIfanboy
Re: Sony INZONE M10S II Oled with pulsar/crt simulation
Post by MSIfanboy » 06 Jun 2026, 15:06
the reviewers says its black frame insertion
LutaKura
Post by LutaKura » 06 Jun 2026, 15:06
Sorry i'm new i don't know how to post links
Baron of Sun
Post by Baron of Sun » 06 Jun 2026, 15:08
Product page says it cannot be used simultaneously with Adaptive Sync / VRR. And it also says using motion blur reduction cuts refresh rate to half, so it seems to be scaler based and not panel based.
https://helpguide.sony.net/tv/27q102/v1 ... 08072.html
LutaKura
Post by LutaKura » 06 Jun 2026, 15:34
Baron of Sun wrote: ↑
06 Jun 2026, 15:08
OOH thank you for the information i missed that, still their BFI seems to behave uniquely to not lose brightness
Post by RealNC » 06 Jun 2026, 16:45
LutaKura wrote: ↑
06 Jun 2026, 15:06
You'll be able to post links after you have 4 posts. For now you can just obfuscate the link like "https dot example dot com/something" and I'll edit it afterwards.
LutaKura wrote: OOH thank you for the information i missed that, still their BFI seems to behave uniquely to not lose brightness
If it's rolling scan rather than full BFI (I hope it is, but I don't know) then they might be boosting the brightness since rolling scan basically mean it's like a 10% window so brightness can be much higher in that rolling bar, like in HDR a 10% window can get much brighter than a 100% window.
nuninho1980
Post by nuninho1980 » 07 Jun 2026, 01:28
If OLED has less than 1kHz for CRT simulation, we don't intereset it.
RAM: 2x16GB DDR4@3600MHz
MB: MSI PRO Z690-A DDR4
GPU: Zotac RTX 4090 non-OC <3 :D
HDD: SATA 1TB
PSU: AEROCOOL 1kW 80+ Gold
Disly: ACER Predator XB273U F5 !NEW! :mrgreen:
SonGohanX
Post by SonGohanX » 15 Jun 2026, 08:59
Is this feature exclusive to the M10S II, or is it on the M10S as well?
LutaKura
Post by LutaKura » 01 Aug 2026, 05:21
SonGohanX wrote: ↑
15 Jun 2026, 08:59
Its only on the M10S II
LutaKura
Post by LutaKura » 01 Aug 2026, 05:25
Now that the monitor is out in the west i can confirm it doesn't work with GSYNC, but the low motion blur feature is still interesting
