NEW 9070xt and my monitor
Posted: 27 Jun 2026, 14:25
by striker333
Hi guyS. i bought new amd 9070xt and using it with my previous monitor the m27qx which i was using with my old card 6900xt. after a fresh windows install i see the colors too faded and the white is too bright with glowing colors . it isn't natural at all . even my friends told me that . i tried different amd drivers and resetting the monitor settings and changed the cable with no fix even tried some recommended windows settings which i turned it off and i switched hdr on and off with no real fix. my old 6900xt was normal but not this. last fix i tried was to resetting monitor using CRU and it didn't fix it . may be it is better now but still not normal colors . i am using windows 11 25h2.of course this causing eye strain and headache. does this mean i have a faulty 9070xt? but instead of color the card performance and temp is excellent with no artifacts. so any help will be appreciated. thx in advance.
Re: NEW 9070xt and my monitor
Posted: 10 Jul 2026, 01:10
by blazerd123
Do you possibly have hdr turned on in windows? Try going to the settings page where you change resolution and toggle hdr off. If that doesn’t solve it try different monitor settings just play around with the options that charge warmth and saturation maybe one if them might fight it
