Hello all,
I've been using NVPI Revamped to allow for 1/3 V-Sync on my games, as my OLED has poor VRR flicker. I was curious to know if there is a way to force V-Sync to automatically change between modes. If I can reach the required FPS for 1/2 V-Sync, then it should use that, otherwise, drop down to 1/3, and then 1/4.
I'm not sure if this functionality is present in NVPI Revamped, I could not find it.
Is anyone familiar with getting a functionality like this to work?
Thanks all!
Variable V-Sync?
- RealNC
Re: Variable V-Sync?
That's not possible. NVPI simply sets driver flags, and the driver has no such feature.
As a side-note, the official NVPI has been completely overhauled now and you might want to switch back to it.
